Proper Tire Inflation - JeepForum.com
post #1 of 11 Old 03-23-2009, 02:31 PM Thread Starter
Dines
I'm showing an unusual tire wear on both tires on the passenger side. The wear seems more in the center and not so much around the edges.
What would be the ideal tire pressure for BFG 33x10.50 R15LT under my current weight for a TJ '01? Thanks, all
Dines is offline
post #2 of 11 Old 03-23-2009, 02:35 PM
TheBoogieman
Disturbed
TheBoogieman's Avatar
Sounds like over inflation.What psi do you run?Alignments and rotation are needed also.
26 psi is what I ran for 33x12.50's. I have no idea what 10.50's run.
TheBoogieman is offline
post #3 of 11 Old 03-23-2009, 02:39 PM
Jerry Bransford
Administrator
Jerry Bransford's Avatar
For a 33x12.50 tire tire, I'd go no higher than 26-28 psi and it sounds like they may have been overinflated higher than that. Some stupid tire jocks think they're supposed to intlate a tire to the pressure molded into the sidewall but that is only the maximum allowable tire pressure to be used only when the tire is carrying its maximum designed-for weight.
Jerry Bransford is offline
post #4 of 11 Old 03-23-2009, 03:05 PM Thread Starter
Dines
I've been running 30psi!
Dines is offline
post #5 of 11 Old 03-23-2009, 03:11 PM
khill8469
when i got my Jeep two months ago i check the air in the tires. all depending on the tires it was from 20 to 50 psi. i put them all at 35. but after reading may post i might lower it some more.
khill8469 is offline
post #6 of 11 Old 03-23-2009, 03:11 PM
Dmcastino
I have 33x10.5 BFG all terrains and I run about 27psi and could still probably go down another pound or two if I really wanted to (my jeep is pretty light though, soft top, no back seat, no spare tire). Discount tire filled them to 36 psi
Dmcastino is offline
post #7 of 11 Old 03-23-2009, 03:13 PM
Dmcastino
What tires do you have and why did you fill them to 35, doesn't the sticker in the drivers side door jam say 33? If you have larger than stock tires you wouldn't want to be above 33psi, you would want to be lower than that.
post #8 of 11 Old 03-23-2009, 03:17 PM
TheBoogieman
Disturbed
Originally Posted by Dmcastino View Post
What tires do you have and why did you fill them to 35, doesn't the sticker in the drivers side door jam say 33? If you have larger than stock tires you wouldn't want to be above that you would want to be lower than that
Misunderstood the post.
post #9 of 11 Old 03-23-2009, 03:18 PM
khill8469
I have 31x10.5x15 cooper discoverer tires now. To be honest with you i wasnt sure what they realy should be set at. So i put them to 35 i might lower them to 32. i need new tires anyways so its just till i figure out what tire and rim combo i want to get.
post #10 of 11 Old 03-23-2009, 03:23 PM
Dmcastino
Never even saw what you originally said, but I just reread my post and I worded it quite poorly lol, no wonder you misread it. I need to add some commas and what not
And Khill, yeah 32ish would probably be a better psi
post #11 of 11 Old 03-23-2009, 03:31 PM
TheBoogieman
Disturbed
I thought you were saying to use higher psi with larger tires when you were saying why did he go so high with smaller tires.I just can't read.
Why not a SCUBA Tank for tire inflation? medcop JK Wrangler Technical Forum 40 08-01-2013 12:49 AM
correct tire inflation? Frozenwalkway TJ Wrangler Technical Forum 10 07-31-2009 04:18 PM
Proper Tire Inflation Pressure Bogus1 TJ Wrangler Technical Forum 4 06-29-2008 07:07 PM
Rubicon Tire Inflation, Valve Stems and more ssi dawgfan TJ Wrangler Technical Forum 31 07-25-2007 09:15 AM
ARB Tire Inflation Kit Idahomie TJ Wrangler Technical Forum 11 11-25-2006 08:57 PM
