Proper four wheel drive engage/disengagment - JeepForum.com
post #1 of 11 Old 12-16-2010, 08:20 AM Thread Starter
DEEPsneaky
I have owned several cj's in the past. This is my first TJ. It is a 2002 sahara with 4.0 and automatic trans . My concern is, when I engage and disengage the jeep from 2H to 4H and vice versa every thing is fine. I can shift on the fly no problems. THe problem comes when I stop to put it into 4L . I stop and put it in N then shift to 4L with no probs but If I am stationary and try to shift out of 4L to N or 4H it grinds like crazy. I have to shut the jeep off then shift to the desired range then start back up. I am trying to sell the jeep and have been telling people about the problem and I think they are scared to buy because of it. I think I may be doing something wrong however because It snowed last night and I drove it around a bit. I shifted to 4L drove around a while then while still moving around 5mph shifted down to 4H and then to 2H with no problems. This tells me I must be doing something incorrectly. Please tell me I'm a moron and there is nothing wrong with my shifter or transfer case. Thanks!
DEEPsneaky is offline
post #2 of 11 Old 12-16-2010, 08:23 AM
austentatious
from what ive always known/done is that you arent supposed to switch in and out of 4lo while moving
O|||||||O
|ProComp|Rokmen|Zone|MetalCloak|RockHard|Mastercra ft|TomWoods|Novak|TenFactory|Synergy|
austentatious is offline
post #3 of 11 Old 12-16-2010, 08:25 AM
JeffBowser
The manual states you should be moving 2-3 MPH when shifting in and out of 4L. That being said, I don't move at all when I shifting in and out of 4L, and have no grinding.
JeffBowser is offline
post #4 of 11 Old 12-16-2010, 08:33 AM
2004Unlimited
In my past four wheel drive experiances, I put the jeep in neutral let it coast to a complete stop, then rapidly through it from 4L into 2H or 4H whichever one you desire. I do not try and "ease" it into gear in past 80's chevy trucks I drove they use to grind like crazy too so I just learned to rapidly "through" it into whatever range I want it and therefore I have no grinding issues with my jeep. Hope this helps
2004Unlimited is offline
post #5 of 11 Old 12-16-2010, 08:42 AM
0blcktj6
I do it while stopped and in neutral and sometimes it grinds sometimes it doesn't, haha. Technically you are supposed to be moving between 2-3 mph coasting in nuetral and you have to do it in one swift motion, the second you try to baby it, it will start to grind or get hung up.
3" Currie progressives, OME Shocks, 1" BL, 1" MML, 35x12.50" KM2's, 4.88's, Detroit in rear, Vanco BBK, Currie CA's
My Build Thread:
0blcktj6 is offline
post #6 of 11 Old 12-16-2010, 09:20 AM
ytowntj
It depends. Mine shifts better when put in at 2-3mph like stated above, but in my dad's LJ is sounds like Armageddon is happening when put in at that speed.
Mine grinds a lot if i put in in 4lo while stopped, but his slips in perfectly then.
I think every Tcase is worn differently, shifter adjusted differently etc so that you should try several ways from rolling at 5mph to stopped and see what is the smoothest in your case.
The Tcase and shifting method in a TJ is somewhat Archaic compared to everyones push button ones of today. It is significantly beefier than most newer ones as well. People arent used to hearing those sounds associated to a vehicle anymore. I doubt that a little grinding going into 4lo while stopped will damage the 231...
ytowntj is offline
post #7 of 11 Old 12-16-2010, 07:39 PM
BlueFlame
BlueFlame's Avatar
^best response.
The owners manuals says to be moving. Mine worked fine when stopped, others not so much.
If you are totally stopped while shifting out of 4Lo, it actually 'could' cause damage. Personally I think it's not really likely to. The trick is to ease on the gas and see if it engaged. If not, try again.
BlueFlame is offline
post #8 of 11 Old 12-16-2010, 07:51 PM
Smitty98TJ
Yeah the manuel does say shift from 2 mph to 3 mph, i just do it when stationary. I ran into a ditch one time while trespassing (unintentionally), crawled out of it and had to run from the owner, shifted back into 2HI when i got back on pavement and heard a loud clanking noise come from the transfer case so i would suggest not shifting back into 2HI over 5 mph.
http://www.jeepforum.com/forum/f22/1998-tj-sport-build-1097517/
Smitty98TJ is offline
post #9 of 11 Old 12-16-2010, 07:54 PM
BlueFlame
BlueFlame's Avatar
Originally Posted by Smitty98TJ View Post
..so i would suggest not shifting back into 2HI over 5 mph.
There is not a problem (normally) shifting from 2hi to 4hi and back to 2hi at any reasonble speed. 55mph is just fine.
The noises were probably because it didn't fully engage. i.e. technique
post #10 of 11 Old 12-16-2010, 08:24 PM
0blcktj6
I think he meant he shifted from 4Lo to 2HI at a speed over 5mph which is definitely NOT advisable.
My Build Thread:
0blcktj6 is offline
post #11 of 11 Old 12-18-2010, 09:34 AM
Smitty98TJ
Yes i did mean 4Lo, sorry about that
Four Wheel Drive Will Not Engage Please Help mulcahy2713 YJ Wrangler Technical Forum 3 05-08-2009 09:56 PM
4 wheel drive will not engage cfuzz1 YJ Wrangler Technical Forum 5 12-29-2008 09:30 AM
4 Wheel drive will not engage Richdog78 YJ Wrangler Technical Forum 2 11-17-2008 04:52 PM
Proper way to put in Four wheel drive Guitarhead09 TJ Wrangler Technical Forum 14 09-27-2007 08:54 AM
How to engage 4 wheel drive? purplewindworm TJ Wrangler Technical Forum 11 09-19-2006 03:26 PM
