#1 | |
Project setup 2.5"OME w/ 1" BL?
After extensive research, I think I may go with the 2.5" OME Suspension lift and a 1"BL probably from JKS.
Any suggestions? and/-or- pics.....with this setup. Thinking on Rock Crawler 15 x 8's with BFG AT 32x11.50's
#2 |
1. Welcome to JF
2. Fill in your rigs specs in your profile I've been running that similar setup but used DPG's coils instead of OME. 2.5 coils OME shocks JKS BL & BMML JKS Adj trackbars Factory Ravines w/ 1.25 spidertrax spacers 33 x 12.5 Cooper STT's Works well for my use. Last edited by 95BadBoy; 03-16-2008 at 03:25 AM.. |
#3 |
Excellent choice. Fill in your profile so we know more about your Jeep. Do you have a 4.0? I think 32s will be ideal for that setup, though Im sure many may push toward 33s. OME provides an excellent ride on the trail and street. The 32s will have less power loss and better fuel economy than the 33s, and have more room to flex. Do you know what your gears are? What rockcrawlers, Alloy or steelies?
OME ZJ/LJ combo | SwayLOC | 1.25" BL | Nth TT | Riddler diff covers | EMP gastank skid | 33" MTRs | Warn M8000 | Cobra75 and much more... Riddler torture test video Oil Filter Study Useful Axle Info Thread |
#4 |
I was having problems editing my profile, so here's what I have so far:
Stock 2003 Jeep Wrangler X/Commando 4.0 I-6 Automatic Gears???? I have no idea, probably factory 3.07 ![]() Stock 15x7 steel wheels w/ cheap tires Soft top All stock...I just purchased the Jeep a few weeks ago from a Jeep dealer. Intentions: Show & go to and from work It'll probably never hit the mud/slopes or do any kind of rock crawling. Just want something other than the stock/boring look without complicating things and getting into turning wrenches and busting knuckles again. That's why I bought a Jeep. KISS method. |
#5 |
The wheels are probably going to be Rock Crawler 15x8 Steel Series 97 or 152(Simulated Bead Lock).
-or- Mickey Thompson 15x8 Classic II's. Which ones would look better? Jeep is silver with a black soft top. |
#6 | |
http://s251.photobucket.com/albums/gg316/95BadBoy/?action=view¤t=3-15-081.jpg |
#7 |
Click free.
#8 |
I have an Unlimited with the DPG set up (see my signature) and 33" tires fit with no rubbing at all, if you do not mind mild rubbing in full stuff DPG even says you can run 35", but I think that would be pushing it......
2005 Unlimited Rubicon bright red, wet okole, 2 1/2" (more like 3"+) HD OME 1 1/4" JKS BL, JKS Discos, 1" JKS MML,28575R16 BFG MTs, Custom HD rear bumper, 2 year old Akita, 9500 lb. milemarker winch, kilby gas tank skid, home made rear bumper and tire carrier, lite dot taillights, more to come!!!!!! Integrity is a rare find! |
#9 | |
did you make them yourself?? ![]() |
#10 |
#11 | |
![]() Yah, I wheel this rig. I don't daily drive it. I just am really judicious as to what line I will or will not take. Really hate bending stuff because my stupid meter was on high. ![]() Last edited by 95BadBoy; 03-16-2008 at 03:27 AM.. |
#12 |
Thanks for the replies and pics
Nice setup on both Jeeps. I'm a fan of factory wheels as well, however mine are the factory 15x7 wheels (standard as standard). I was looking on ebay before I posted this thread for factory Jeep wheels. Will 2007/2008 17 and 18 inch wheels work on a 2003 hub? I like the factory 16" wheels like you all have, however I can't seem to find any on ebay. Are your tires 33x11.5's or 33x12.5's (equivalent)? |
#13 |
nope they are a different bolt pattern, you could run them with an adapter
Wars may come and go, but my soldiers remain Eternal. It's nice being just down the road from DPGoffroad. Now a 99 SAHARICON!!!! |
#14 |
What type of adapter do you recommend?
#15 | |
![]() Spidertrax adapters: http://www.spidertrax.com/s.nl/it.A/id.2131/.f
| Thread Tools | |
Previous Thread
Next Thread
| Suggested Threads |
