Quantcast Project CRRWLR - Page 5 - JeepForum.com
Go Back JeepForum.com > Models > Jeep Wrangler Forums > TJ Wrangler Technical Forum > Project CRRWLR
Old 04-30-2008, 06:00 PM   #61
bman9089
You get what you pay for
bman9089's Avatar
Originally Posted by green98xj View Post
the old one hit the skid plate when the axle drop like an inch or so so this one is only 2.5 in outside diameter and hits when it drops alittle more i forgot how much exactly ill put it on let you know and post a pic
so you got a new driveshaft because of the stock skid getting in the way? Am I reading that correctly?
"The American Republic will endure, until politicians realize they can bribe the people with their own money." -- Alexis de Tocqueville
“Sometimes I wonder whether the world is being run by smart people who are putting us on or by imbeciles who really mean it” -- Mark Twain
† Christian Jeep Club †
Romans 12:5 | 1 Peter 3:15 | Matthew 9:37-38
bman9089 is offline   Reply With Quote
Old 04-30-2008, 10:00 PM   #62
JeepRocks86
Some Call me RockDog
JeepRocks86's Avatar
the front hub for the 03 TJ is 169 which isn't good since I think i need to possibly replace one.
71.29 for the 98... not fair
Stretched TJ Future, Coil overs, 40s, 60/14 bolt
My Build Thread.
www.kifourwheelers.com www.indyorv.com
For Sale:
TJ 44 Combo, 4.88s, detroit, Alloy USA shafts, Disc Brakes, HD lower mounts, Clayton tube Truss
35" procomp tires with Aluminum wheels $650
(4) 5x4.5 steel beadlocks $200
3 11"& 2 13" BBCS shocks
Ford Dana 60 Rear $150
Big Daddy Offroad HD tie Rod
(4) 15x8 5x4.5 TJ, YJ, XJ, etc bolt pattern Aluminum wheels $175
JeepRocks86 is offline   Reply With Quote
Old 04-30-2008, 10:18 PM   #63
Dan Fredrickson
Vendor
Dan Fredrickson's Avatar
Hey Matt, nice looking build......
I have to ask you, it looks like you had 3/4" clearance before you added more to the cover, how big is the JCR shaft in diameter? We haven't had any clearance problems that weren't toe related?
Dan Fredrickson
www.ruffstuffspecialties.com
Much Better Than Good Enough
Sales 916.509.2242/Sales & Tech 916.600.1945
Dan Fredrickson is offline   Reply With Quote
Old 05-01-2008, 10:45 PM   #64
green98xj
no i got a new drive shaft because the stock driveshaft outside diameter is like 3 in and was 1/4 -1/2 of hitting the fulltraction skid plate.
Gravel maker
the problem occuried whenthe sterring was at full lock towards the driveside.
the jcr steering is 1 1/4 o.d.
1998 TJ SPORT.. CRAWLER IN THE MAKING
green98xj is offline   Reply With Quote
Old 05-02-2008, 11:56 PM   #65
02tjsport
Did you have to paint your Tie ROD on your JCR setup. I just got mine and cant tell if the rod itself is bare metal or if it has paint on it. Im thinking of spraying some rustoleum either way.
'02 TJ Sport - 3.5" RE Springs/Mono-tubes; BFG A/T 33x12.50x15 on ProComp Black Steelies; JKS: BPE's, 1.25" BL, shock conversion, front Adj. TB's, quick discos, Extended Brake lines; FT 3-link rear; JCR 1-ton Steering; Warn 6" Flares; Olympic Slider Bumpers; OME SS; Taurus Electric Fan; 4.88 Gears; D30/D44 Detroit True-Trac Front/Rear;
02tjsport is offline   Reply With Quote
Old 05-03-2008, 01:13 AM   #66
green98xj
i painted its bare metal!
Old 05-03-2008, 01:29 AM   #67
charlescho
harness bar way too low. i hope with the simpson seats its about your shoulder height.
also great build man how are you bolting the 5 point to the cage/tub? angle clevis?
[SIZE="3"][FONT="Impact"][COLOR="Cyan"]ABC - A/Ox4 - SAMPLE - OPQRST[/COLOR][/FONT][/SIZE]
charlescho is offline   Reply With Quote
Old 05-03-2008, 08:15 AM   #68
Luke4554
Hey man ive almost got to the point i can fab my brackets lol. I decided to herculine my bed the same day the seats showed up so its delaying the process but heres a picture of mine mocked up on the stock sliders. They look pretty nice in there and even just sitting how they are in the jeep they are super comfortable.
Luke
[SIZE="1"][B]2000 TJ Sport[/B]
4.0L | 5spd | 4" SkyJacker | Soft 8's | 33" TRXUS | 30/35 | AA SYE/CV DS | SuperWinch | 4 KC's | Pure Bred Tube Fenders | EMPI Buckets | Novak Linkage| Pure Bred Bumpers | Bestop Tinted Soft Top & Bikini | HiLift | Yellow Top | Herculiner | JKS Discos | Skid Row Steering Skid
[b]Owner of [U]WWAutosports[/U] & [U]Pure Bred Fabrications[/U] Dayton, Oh[/b][/SIZE]
Luke4554 is offline   Reply With Quote
Old 05-03-2008, 01:50 PM   #69
green98xj
looks good!
i have only pulled the passanger side out thats gonna be my next step.
Old 05-06-2008, 11:12 PM   #70
green98xj
heres a couple pics of the seat bracket we fabbed up!
Old 05-07-2008, 06:17 AM   #71
charlescho
shoot me a picture when you mount the 5 point harness. I'm interested
Old 05-07-2008, 08:14 AM   #72
Luke4554
I made my drivers side last night .. i ended up angling the bracket a bit because if you look at the slider its cocked sideways in the tub. I think the factory seats bracing are sideways a bit too under the skin to straighten out the seat. Ill post pictures of mine tonight .. but its the same basic idea as yours, but with a little more bracing (i was worried about jouncing up and down from off road use and having structural issues with weight in the seat. Looks good though.
Luke
Old 05-07-2008, 09:32 AM   #73
green98xj
luke the stock seats arent straight on the brackets they sit towards the center of the jeep more make sure you can close the door.i almost foregot to check that..
Old 05-07-2008, 09:36 AM   #74
Luke4554
yeah i havent put my doors back on yet to check it .. but with the seat in there it appears that the doors will have enough clearance. Being that my 80lb doors are hanging up in my garage about 8 ft up the wall is making me annoyed knowing i have to take them back down again.
Ill have to check everything and see how it clears .. worst case scenario ill just drill holes in different orientations on the brackets to manipulate the seat side to side and front to back.
Luke
EDIT..
I re-read your post .. my brackets are still offset to the center .. the angle i was speaking of (drivers side point of view) is the front of the slider is closer to the drivers side of the tub than the rear .. from behind making it look like " \ " .. rather than " | " head on.. because upon first mock up my seats where angled out like " \ / " slightly on each side because i had set them on the sliders so they were parallel with the brackets.
Old 05-07-2008, 11:01 AM   #75
1speedlos
Sorry for the hijack...
green98xj- so what singlespeeds are those I see in the background?
Good to see other disciples in the Church of the Rotating Mass...
Los
1speedlos is offline   Reply With Quote
Glock Forum
