#31 | |
Who makes these seats? Where did you get them? What's the plan for seatbelts?
That ought to get the job done. Looks like some serious beef!
For Sale: Catch-All rear floor liner for YJ (charcoal in color) - $25 |
#32 |
#33 |
[QUOTE=Matt Graham;5104144]Who makes these seats? Where did you get them? What's the plan for seatbelts?
EMPI makes the seats! http://www.actionimport.com/Catalog_EMPI/Race-Trim_Seats.htm Seat belts simpson harness ill post some pics when i get off work hoping to have my gibson header today too..
1998 TJ SPORT.. CRAWLER IN THE MAKING |
#34 | |
#35 |
Some Call me RockDog
looks good. TOok us a while to figure out where that gusset went since the directions sucked.
Stretched TJ Future, Coil overs, 40s, 60/14 bolt My Build Thread. www.kifourwheelers.com www.indyorv.com For Sale: TJ 44 Combo, 4.88s, detroit, Alloy USA shafts, Disc Brakes, HD lower mounts, Clayton tube Truss 35" procomp tires with Aluminum wheels $650 (4) 5x4.5 steel beadlocks $200 3 11"& 2 13" BBCS shocks Ford Dana 60 Rear $150 Big Daddy Offroad HD tie Rod (4) 15x8 5x4.5 TJ, YJ, XJ, etc bolt pattern Aluminum wheels $175 |
#36 |
Simpson Harness
i got them for 80 ea on simpson site http://simpsonraceproducts.com/products/offroad_rest_latchlink.aspx ![]() ![]() my cb ![]() modified the Ruffstuff diff to clear the jcr 1 ton steering ![]() ![]()
#37 |
Am i reading right that those seats are $250 for the set?! Those look just like mastercrafts. BTW how much are those PSC corners with no flare.. im trying to find an affordable set with no flare that way i can decide later if i want to fab up custom flares for them or not.
Luke
[SIZE="1"][B]2000 TJ Sport[/B] 4.0L | 5spd | 4" SkyJacker | Soft 8's | 33" TRXUS | 30/35 | AA SYE/CV DS | SuperWinch | 4 KC's | Pure Bred Tube Fenders | EMPI Buckets | Novak Linkage| Pure Bred Bumpers | Bestop Tinted Soft Top & Bikini | HiLift | Yellow Top | Herculiner | JKS Discos | Skid Row Steering Skid [b]Owner of [U]WWAutosports[/U] & [U]Pure Bred Fabrications[/U] Dayton, Oh[/b][/SIZE] |
#38 |
I'm sure you will, but be sure to post a pic of those seats & belts installed! This thing is going to be nice!
#39 | |
i think the corners were 299 from psc..
#40 |
'02 TJ Sport - 3.5" RE Springs/Mono-tubes; BFG A/T 33x12.50x15 on ProComp Black Steelies; JKS: BPE's, 1.25" BL, shock conversion, front Adj. TB's, quick discos, Extended Brake lines; FT 3-link rear; JCR 1-ton Steering; Warn 6" Flares; Olympic Slider Bumpers; OME SS; Taurus Electric Fan; 4.88 Gears; D30/D44 Detroit True-Trac Front/Rear;
#41 |
#42 |
its a brace that comes with the fulltraction kit..
#43 |
Your gunna have a good looking rig!!!! good job!!!!
4inch supsension 1.25BL 1MML, 4.88s, 35 MT MTZ, LOD front bumer rear tire carrier, AtoZrockerguards, SYE+CVdriveshaft, I-6, Durango steering box, IPF headlamps-fatboy bulbs, and in the spring custom long arm suspension (copying claytons arms and modifying brackets) |
#44 | |
BTW are they comfortable? Im not sure if youve sat in mastercrafts but theyre awesome. Just curious if theyre comparable. Also did you buy slides for them or are you fitting them solid or retrofitting them with your factory sliders? Im thinking of running bars under the seats and making brackets for my stock sliders. Luke
#45 | |
| Thread Tools | |
Previous Thread
Next Thread
| Suggested Threads |
