Programmers - JeepForum.com
Go Back JeepForum.com > Models > Jeep Wrangler Forums > TJ Wrangler Technical Forum > Programmers
Spartan Locker Promo Running now @ ROCKRIDGE 4WD plus FREEYukon Ultimate 35 axle kit for c/clip axles with Yukon ZipNitro Gear Packages Now Available at Rockridge 4wd
Unread 01-13-2015, 07:49 PM   #1
Denbowcj7
Programmers
Anybody having a programmers on their rig? Need opinions for the best one.
I have a 02 tj 4 banger. 5 speed with 32x11.50's. Looking to get a little better mpg and boost my horse power up some.
Denbowcj7 is offline   Reply With Quote Quick reply to this message
Unread 01-13-2015, 07:58 PM   #2
Unlimited04
This post/info=my opinion
Unlimited04's Avatar
regear to 4.56s or 4.88s.
Unlimited04 is offline   Reply With Quote Quick reply to this message
Unread 01-13-2015, 08:16 PM   #3
PhulesAu
Search!!! There are no programmers for you!
PhulesAu is offline   Reply With Quote Quick reply to this message
Unread 01-13-2015, 09:40 PM   #4
RnEmOvr
Have Cummins, Will tow.
RnEmOvr's Avatar
I've seen many people do things to their little 4 cyls and only two options have proven to help. Regear or motor swap.
RnEmOvr is offline   Reply With Quote Quick reply to this message
Unread 01-14-2015, 05:50 AM   #5
TJ4Jim
You can swap out your throttle body for the 4.0 version. All you need is a used body and a new gasket. Used body's are easy to find and all you have to do is clean it up and transfer your 2.5 TPS and IAC devices. Not a power adder but will improve throttle response.
TJ4Jim is offline   Reply With Quote Quick reply to this message
Unread 01-14-2015, 08:37 AM   #6
TheBoogieman
Demonic Jeep Freak!
TheBoogieman's Avatar
Regear or draft behind a 4.0 with 3.07's.
When I had 3.07s I would draft behind birds as an attempt to do the speed limit.
2000' WJ Limited 4.7L-V8/D44/Quadra-Drive/31" MT's/3" lift
TheBoogieman is offline   Reply With Quote Quick reply to this message
Unread 01-14-2015, 08:52 AM   #7
jjvw
jjvw's Avatar
Or you could press the gas pedal a little harder. That does the same thing for free.
'03 Rubicon
jjvw is offline   Reply With Quote Quick reply to this message
Unread 01-14-2015, 11:17 AM   #8
TJ4Jim
No, not really the same thing.
Unread 01-14-2015, 01:13 PM   #9
JeeperLink
2001 Wrangler SE 2.5L
This is me every time I get on the highway..
JeeperLink is offline   Reply With Quote Quick reply to this message
Unread 01-14-2015, 01:22 PM   #10
TheBoogieman
Demonic Jeep Freak!
Unread 01-14-2015, 02:18 PM   #11
Orannis
Regearing is really the only way to go (unless you opt for an engine swap). There are some mods that probably do increase power a bit, but the eventuality is that the horsepower gain is negligible and you will just wear your engine out way faster. I have 4.88s and 33s and have no trouble on the freeway nor do I lack power offroad. I would like a 4:1 conversion in my t-case though
Orannis is offline   Reply With Quote Quick reply to this message
