Problems with wiring harness and defroster - JeepForum.com
post #1 of 2 Old 07-17-2005, 01:38 PM Thread Starter
hiyamoose
I got a wiring harness from jeepsareus for a 98 TJ and 2003+ hardtop. They spliced two harnesses together and everything fits. Only problem is, actually two problems, the defroster does not work - the light on the switch will not illuminate.
Couple of questions...
Will a 40 amp fuse, rather than a 30, in the PDC affect this? When I got the box from jeepsareus, the fuse was a 40 rather than a 30.
Also, I have not attached the two terminal wires to the instrument panel cluster connector. Figures I could get through every step of installation except the very last one. Both slots on the I/P cluster already had connectors. One dead ended @ 3" out. The other led off into the dash somewhere. First, what do I do to get the terminals to where they need to go? Second, will not connecting these terminate a circuit or something that will kill the defroster? It didn't look like it.
The windshield wiper and fluid spray work perfectly. Just got to solve the defroster problem.
help...please...
hiyamoose is offline
post #2 of 2 Old 07-17-2005, 06:14 PM Thread Starter
hiyamoose
btt...Bueller...Bueller
...going back for round 2 of wiring the hardtop.
Ongoing wiring harness problems.. need help! gsmith795 YJ Wrangler Technical Forum 2 06-25-2009 01:47 PM
Wiring problems after swap, which harness will work? Drdan524 YJ Wrangler Technical Forum 1 05-03-2009 01:20 PM
Engine wiring harness Problems Spigger73 YJ Wrangler Technical Forum 9 01-07-2006 10:16 AM
Factory Fog wiring Harness Problems... DaveFL TJ Wrangler Technical Forum 3 11-29-2005 04:31 PM
Wiring harness problems?? Triph75 YJ Wrangler Technical Forum 1 10-03-2004 11:18 AM
