Problems with second gear - JeepForum.com
post #1 of 3 Old 05-17-2004, 10:03 AM Thread Starter
AggieTJ
First of all, I have the RE t-case drop kit installed along with the RE 3.5 lift. So far no problems with drivability, other than always having to hold onto the shifter when selecting 2nd, 4th, or reverse gears. Otherwise, they tend to pop out of gear when the clutch is first released. Now over the weekend while driving the Jeep on the street, I shifted to second and could not get it into gear. No matter what I did, it would not go into second. I reached my destination by skipping second every time, then tried it once more. Ramming it into second with a healthy dose of the throttle applied, the tranny finally found second gear again. Later on the way home, I had no trouble. Any indication of a major problem here? Maybe some of you have encountered this with lifts installed(?).
'03 Wrangler Sport
RE 3.5" lift, RE front adjustable track bar, OME Nitrocharger shocks and SS, Cragar steels, BFG 33x12.50 Mud-Terrains. LoD rear bumper and tire carrier, Bestop Bikini top.
AggieTJ is offline
post #2 of 3 Old 05-17-2004, 10:23 AM
igofshn
Locked @ both ends
igofshn's Avatar
Remove the shift boot and trim the metal around the bottom of the opening. This is common because you tilted the motor and tranny back.
2007, 4 door, powered by a minivan engine, locked and riding on 35's.
igofshn is offline
post #3 of 3 Old 05-17-2004, 01:56 PM
rajincajingt
rajincajingt's Avatar
1983 CJ7
this is from the lift, i had the same problems, i installed the b&m short shift stick from summit racing and that took care of it all. the guy who put my lift on suggested that we take the boot off, heat up the shifter and bend it so you can find 2nd 4th and reverse. i choose the first option. but just to make sure, you should take off both boots and make sure that the clearence is your problem. if you seem to be clear of the boots and you are not hitting sheetmetal when you hit those gears, you have another problem. hope this helps...
83 cj
70 commando
76 c30
rajincajingt is offline
4th gear problems 03Wrangler TJ Wrangler Technical Forum 0 05-17-2008 10:06 PM
D44 Gear Problems, shaft problems. lazerusrm TJ Wrangler Technical Forum 7 04-09-2008 06:29 PM
2 nd gear problems. RedRock84 JK Wrangler Technical Forum 3 02-10-2008 09:58 AM
4th gear problems FranV TJ Wrangler Technical Forum 2 09-08-2007 11:41 AM
2nd gear problems OB1 YJ Wrangler Technical Forum 3 04-11-2005 07:29 AM
