Problems with Idle RPM way too high. - JeepForum.com
post #1 of 5 Old 02-11-2012, 03:56 PM Thread Starter
Cjonck1774
I've had my Wrnagler TJ for about 4 years now, and when ever it gets cold here in TX my Idle RPM's are about 1500. In trying to fix this problem I haveput on a Brand new TPS and IAC on the throttle body. After doing so the jeep now starts off Idleing fine when the engine is cold but as it warms up it will climb to close to 2000 RMP when out of gear, and when its in gear and moving it will go back down to lower RPMs until you hit that red traffic ligh and it jumps up agian. I dont know if it effects anything but it also has a AEM intake that has been there since i bought it... Again this usually only happens during the winter. Does anybody have any suggestions as to what the problem might still be?
Cjonck1774 is offline
post #2 of 5 Old 02-11-2012, 04:01 PM
tac426
try unhooking the battery for 10 minutes or so, then hook it back up the computer may fix it as it goes through its startup sequence.
good luck
tac426 is offline
post #3 of 5 Old 02-11-2012, 04:03 PM
Barcus
check the bolts on your exhaust manifold and check for any leaks in your exhaust. if you have an exhaust leak, you will idle higher. typically, if any bolts are going to be loose, they are the two closest to the firewall. when I had your problem, they were only finger tight.
98 TJ Currie arms-RC 2.5 coils-RC 2.0 shocks-1.25 BL-TF rear track bar-custom bumpstops-mud-scratches-gas.
Barcus is offline
post #4 of 5 Old 02-11-2012, 04:04 PM
colaman24
Check for a vacuum leak, 2 to 3 lines come off the intake. If one gets old and cracks, it leaks am and will accelerate your rpms
colaman24 is offline
post #5 of 5 Old 02-11-2012, 07:16 PM
guy.griffin
guy.griffin's Avatar
1997 XJ Cherokee
also check injector seals. Get some throttle body cleaner spray around injectors while its running the idle drops as your spraying than you have bad seals
guy.griffin is offline
idle , rpm , throttle body
*sigh* Encountered my 1st few problems with my new Jeep - Need help (high idle) Must-Be-A-Stang TJ Wrangler Technical Forum 23 04-24-2010 02:56 PM
High Idle, High Pitched Whine, Black Soot PolakX TJ Wrangler Technical Forum 6 02-15-2010 07:34 AM
High idle 2k rpm, idle jumping on braking - Moab in jeopardy AndrewMuadDib TJ Wrangler Technical Forum 9 09-06-2009 10:19 AM
t-body problems. idle high Msegars TJ Wrangler Technical Forum 8 05-07-2009 09:49 AM
high idle problems KU krawler TJ Wrangler Technical Forum 1 06-11-2004 08:19 PM
