Problems with gauges dropping to zero and/or spiking and Jeep stalling - JeepForum.com
post #1 of 30 Old 08-30-2010, 12:52 PM Thread Starter
Sidewaize
Hello all,
I just started my vacation and I'm taking the jeep. Unfortunately it has started acting up severely and I can't seem to figure out what is wrong. If anyone has any ideas, I would greatly appreciate it.
The problem:
The issue usually happens while driving down the highway, usually 50-60mph, while under light load such as a hill.
The tach suddenly drops to zero, then spikes back up to the proper rpm (This happens so fast it took me a while to notice it). There is a sudden clunk as the slack is taken out of the drivetrain. The speedometer quickly drops about 15mph then spikes back up to proper speed. The oil pressure gauge slowly drops to about 20psi, then slowly climbs back up to about 60psi.
All of this happens within about 1.5 seconds, just to put it into perspective.
I've also found that something similar happens at idle, at random times.
The tach will drop to 0, the engine will stall, and the oil pressure will drop to 0, then slowly pick back up. On rare occaisions, the jeep will die completely when this happens at idle.
Please help, nobody has been able to give me a solution.
Thank you,
Josh
Sidewaize is offline
post #2 of 30 Old 08-30-2010, 01:03 PM
Benderff
Benderff's Avatar
Do you have any codes showing up? Is this the same problem you had last year at this time?http://www.jeepforum.com/forum/f9/en...d-help-584183/
On a side note do you work for the GPDPS? I have a few friends on the fire side.
Benderff is offline
post #3 of 30 Old 08-30-2010, 01:24 PM Thread Starter
Sidewaize
Yeah, I sure do... Pretty cool to find you on here. Yeah, it's the same problem. But ive been able to figure more things out and really see what it's doing on this trip. And it's increased dramatically in frequency. So I would like to figure it out before whatever it is dies completely.
No codes so far. So I'm at a loss.
post #4 of 30 Old 08-30-2010, 03:08 PM
wushaw
Rockin jeep
wushaw's Avatar
Try cleaning your battery terminals shinny clean.
wushaw is offline
post #5 of 30 Old 08-30-2010, 07:59 PM
J03_TJ
There were two times on all my years of driving that my gauges went nuts. 1st was the tach in my 2001 dodge truck, turned out to be a crankshaft position sensor. Second was in my jeep. All the gauges started going haywire like it was possessed when I turned on the ignition key (don't think it would start though), it was a bad battery that time. Good luck.
J03_TJ is offline
post #6 of 30 Old 08-30-2010, 08:31 PM
Recoil
Recoil's Avatar
1988 MJ Comanche
yeah it sounds like battery to me. Have a local parts store test it for you. If thats not it Ill check back in tomorrow while at work and see if there are any tsb's related to this or anything in ifix
Recoil is offline
post #7 of 30 Old 08-30-2010, 10:14 PM Thread Starter
Sidewaize
I hope so... I'll get it check tomorrow. Thanks for the input.
post #8 of 30 Old 09-01-2010, 09:19 AM Thread Starter
Sidewaize
So I cleaned the terminals sparkling clean, and had the battery tested. Battery is good. And i thought maybe i was fixed. but out on a drive last night and it acted up again. I'm at a loss Here.
post #9 of 30 Old 09-01-2010, 09:55 PM Thread Starter
Sidewaize
Ok, Update. I checked the battery, it's good. Scanned codes again. Nothing there. I have an after market alarm and thought maybe it was the starter kill. So I unplugged the alarm completely. Still doing it. Any ideas? I'm starting to think its the computer.
post #10 of 30 Old 09-03-2010, 12:02 PM Thread Starter
Sidewaize
It feels like a brief stall..
post #11 of 30 Old 09-03-2010, 12:24 PM
stevefarling
My wife's XJ was doing the same thing a couple of years ago. I was at a loss and took it to the dealer. They said it was a ground wire. It seem like it might have been behind the engine to the firewall. I would check the main ground and any others you can find. I hope this helps.
stevefarling is offline
post #12 of 30 Old 09-09-2010, 01:51 PM Thread Starter
Sidewaize
Well, I checked all the grounds and they are tight. (The one on the firewall and the one on the engine block) Just stumbled again today. This is frustrating.
post #13 of 30 Old 09-10-2010, 11:27 AM
Benderff
Benderff's Avatar
How do your battery cables and Alt cable look? I would look at the main power cables really well.
Benderff is offline
post #14 of 30 Old 09-10-2010, 12:26 PM Thread Starter
Sidewaize
They look good. The jeep has 111000 miles on it though. Do you think it would be worth changing them out first?
post #15 of 30 Old 09-10-2010, 02:50 PM
JFjeld
I would still suspect the battery. I had this happen, although not while running; just when I tried to turn it over (gauges spiking, etc). When you had the battery checked, did they just check voltage, or amperage also? In my case, the voltage was fine, but amperage was too low.
If nothing else, I would suggest trying a similar battery from a friend, etc. and see if you have the same thing happen. If no problems, you know for a fact it is the battery.
01 TJ,HPD30/D44,OX,4.88,35s,1"BL,1"MML, 4.5" lift,OBA,Novak Shifter,Teraflex ESS SYE, UCF tummy tuck
JFjeld is offline
cluster , cranks , guage , idle , instrument , stall
Audiovox CCS100 Cruise Control problems - Jeep stalling LARSONEM TJ Wrangler Technical Forum 3 05-06-2010 09:31 AM
Shift Linkage problems when dropping man tranny Ofsthun YJ Wrangler Technical Forum 1 11-22-2009 12:22 AM
Voltage spiking - starting problems - help Want24Wheel TJ Wrangler Technical Forum 1 05-09-2009 04:50 PM
Newby needing help with Check engine light/check gauges/stalling DannyDuvall TJ Wrangler Technical Forum 2 08-23-2008 08:02 AM
jeep having stalling problems dragonjeep TJ Wrangler Technical Forum 4 05-07-2005 12:48 PM
