#1 | |
Problem Removing Torx Bolt
I am having issues removing the torx bolts from the bottom of my front bumper. As you can see in the picture, the corners are starting to get rounded off. Anyone have any suggestions as far as how to get this off with out destoying it?
"Your eyes can deceive you, don't trust them." |
#2 |
I used a smaller pipe wrench on mine. Then I threw the torx bolt away so it counldn't harm others. The threads are a good old 1/2 inch 13 threads per inch. When you get them out just throw them away. Just replace with a good grade of bolt and be ddone with it.
For bumper bolts never-sieze is a good idea.
Jim United Steelworkers Union member 99 TJ Sahara 4.0 5-Sp FUV + farm worker Project f-Xj F150/XJ Ford eXtreme jeep combo 06 6 Speed LJ my daily driver. Colorado Jeep club memeber #505 |
#3 | |
#4 | |
gently tap the torx into the head of the bolt to deepen and true up the slots |
#5 |
If your still having problems - I would suggest you get a dremel and shave off two sides of the bolt say, 3 o'clock side and 9 o'clock. Now take a pair of vice grip pliers and twist it off.
Oh yeah replace the bolt with a normal hex shaped one... Vise grips have saved my behind on several occasions. |
#6 | |
#7 |
I had the same problem. Spray it with some pb let it sit for a little while then get a pipe or some sort of breaker bar. Shouldn't have any problems.
1970 CJ5 (DD) |
#8 |
lol had the same problem with all my TORX .. I ended up up drilling the heads off to a point where I can slip the item off, then using WD-40 (full can) I grabbed the remaining bolt with a vise grip and removed it that way.
All the above are good ideas, mine is the extreme, and it sucks!!!! |
#9 |
PIPE WRENCH/MONKEY WRENCH
really. that torx shape is toast. putting flats on it then a crescent wrench is spending too much time on a defect in steel. Borrow, buy, steal even a small SHARP pipe wrench and dig those teeth into the head of that little piss ant of a fastener and lean on that sucker till it screams to be loose. I want to strangle the person who LOOKED at the guy who invented the torx and said..."Great Idea!!"
78 CJ5 04 TJ "U" package 06 XK Commaddy Jeep mods do not fix poor driving or stupidity. |
#10 |
what i did to get mine off i had a similar problem i used a torch to heat it up then i used a cold chizzle and a mini sledge and used that to turn it the way i wanted worked perfect..i kept heating it and doing that until it was loose enought that vice grips would turn it
88 jeep wrangler, 4.2, auto---cragar soft 8's, d35 locker, bucket seats with 5 point harnesses, warn bumper w/ grill gaurd, winch plate, kc daylighters, light bar, herc the interrior, rebuilt tranny (yay) with tranny cooler, winch and msd ignition, 3.5 inch fabtech lift, currie boomerang shackles f/r, weber carb...[B] [B]Why only go anywere fast when you can go anywhere[/B] |
| Thread Tools | |
Previous Thread
Next Thread
| Suggested Threads |
