Problem with Dana 44s in a TJ - JeepForum.com
post #1 of 7 Old 04-25-2008, 11:01 AM Thread Starter
hoggster
Hi, I'm helping a friend put a pair of dana 44s with OX lockers in his '97 TJ Wrangler. The front axle seals are some kind of aftermarket seal with a red annodized metal body that protrudes from the axle tube. The seal part looks like a normal seal that would be used from front engine seals, etc. I'm sorry if I don't know correct terminology for everything, I am a Volvo/Saab mechanic with little 4X4 experience.
We have the rear put in and everything went smoothly. We have the front installed, but we are having a problem with it. The side with the short shaft is fine. The problem is with the other side.
When you turn the steering knuckle, the axle shaft itsself moves from front to back. You can actually see the seal deflecting from this. The range of movement is around 1/4". We have the hub bolted down and the spindle nut installed, and as far as I can tell the Upper and Lower ball joints are also tight.
The shaft doesn't look like its pushed too far in, and the spindle nut should hold it in its correct position anyway.
We popped the diff cover off trying to see if something is improperly installed, but you really can't see anything with the locker mechanism in there.
Is the shaft supposed to move? What is supposed to support the shaft? Thanks.
hoggster is offline
post #2 of 7 Old 04-25-2008, 11:18 AM
Dravintoad
Dravintoad's Avatar
Sounds like you got the alloy usa axle seals on there. Those don't support the axle shaft, They just help keep the crap out better than the plastic ones that come stock.
Hard to figure out the axle shaft movement without seeing it.
Do you have pics?
Nothing to see here.
Move along.
Dravintoad is offline
post #3 of 7 Old 04-25-2008, 11:24 AM Thread Starter
hoggster
Unfortunatly I don't have pictures. I might be able to get some later this weekend.
Is there supposed to be a bearing or something behind the seal to hold the shaft, or is it only supported at the differential and the hub?
The shaft is moving horizontaly from the front to back when you turn the steering knuckle. The movement is severe enough to cause that seal to shift with it.
hoggster is offline
post #4 of 7 Old 04-25-2008, 11:26 AM
Dravintoad
Dravintoad's Avatar
No, The axle shaft slides through an inner seal and is supported internally and at the hub. It basically floats on the outside at the aftermarket seal.
EDIT: I have never looked to see what kind of movement there is at the axle end, so sorry
Move along.
post #5 of 7 Old 04-25-2008, 11:28 AM Thread Starter
hoggster
What is supposed to keep it centered in the tube?
hoggster is offline
post #6 of 7 Old 04-25-2008, 11:28 AM
Jerry Bransford
Administrator
Jerry Bransford's Avatar
The front axleshaft is supported by the unit-bearing hub on the outside, and the carrier inside the differential. Those two keep it centered That seal, as noted, is an aftermarket seal who's purpose is only to help seal the axle tube from mud, dirt, etc. Is the unit bearing hub secure and in good condition? Is the carrier present inside? Something is really wrong somewhere if you can see the axleshaft moving like that.
Is the front axle fully installed? Does it have the trackbar (you probably know it as the panhard bar) installed? Both lower control arms and the upper control arm are installed?
Getting
Jerry Bransford is online now
post #7 of 7 Old 04-25-2008, 11:44 AM Thread Starter
hoggster
I'm only looking at the seals movement as an indication that the shaft is moving too much, I realize it doesn't support the shaft.
The hub is secured to the knuckle, which is secured to the ball joints. However it is the original hub. It does not appear to be worn out, I will check for play in it next time I'm working on it. EDIT hub has no play.
The axle was doing this sitting on the ground uninstalled, and does it partially installed on the Jeep (upper and lower control arms and driveshaft) The steering is not installed, nor is the track (panhard) rod.
hoggster is offline
dana 30 problem? timritchieblue TJ Wrangler Technical Forum 11 10-03-2009 08:59 PM
Dana 30 Problem Ratmeat YJ Wrangler Technical Forum 5 09-14-2009 08:29 PM
Dana 44 Rearend Problem gotriver TJ Wrangler Technical Forum 12 06-03-2009 05:20 PM
Dana 30 Problem???? bddisi TJ Wrangler Technical Forum 20 12-06-2008 10:00 AM
Dana 35 axle problem Serafim TJ Wrangler Technical Forum 9 07-16-2008 07:33 AM
