Pro Comp - 1'' Front Coil Spring Spacers - JeepForum.com
post #1 of 13 Old 07-06-2010, 07:36 PM Thread Starter
JWs06TJ
I have a 06 TJ with front end sag from a winch and mount I want to shim the front springs and was just wondering if the metal Pro Comp - 1'' Front Coil Spring Spacers would be better than the poly spacers for this thank's
JWs06TJ is offline
post #2 of 13 Old 07-06-2010, 08:02 PM
aussie1
i would like to know also. i have aabout and 1'' sag too.
More Than
Just A Jeep...
It's a
Way of Life!
aussie1 is offline
post #3 of 13 Old 07-06-2010, 08:06 PM
BlueFlame
BlueFlame's Avatar
I personally prefer poly spacers.
More 'cushining' effect, and issues with no corrosion etc.
BlueFlame is offline
post #4 of 13 Old 07-06-2010, 08:18 PM
MisfitSeven
MAiL Crawler.
MisfitSeven's Avatar
Originally Posted by BlueFlame View Post
no corrosion
another vote for poly.
Mail crawling.
MisfitSeven is offline
post #5 of 13 Old 07-07-2010, 06:28 AM
Zen
Another vote for poly. Polyurethane is more than capable of holding the load, it's cheap, weather proof, and quiet. Plus if you get black 3/4" or 1" spacers, they are so small they aren't really noticable.
-Darkstar, judy-judy. I'm going in for guns.
-Stick, splash one!
Zen is offline
post #6 of 13 Old 07-07-2010, 06:48 AM
TheBoogieman
Disturbed Jeepaholic
TheBoogieman's Avatar
Poly..................
TheBoogieman is offline
post #7 of 13 Old 07-07-2010, 09:24 AM
Neil F.
For 1" spacers, these are the cheapest I found Crawler Ready - 1" Jeep Coil Spring Spacers I recently got a set. There are a number of 3/4" available but not that many 1"
Neil F. is offline
post #8 of 13 Old 07-07-2010, 09:44 AM
mpd2434
2014 JK Wrangler
Damn I couldn't find 1' coil spacers when I lifted my Jeep so I went with the 1.5" ones. Glad I did because my Jeep still sits slightly lower in the front but I think it looks better that way anyway. My winch also weighs 100lbs with the winch plate attached so i'm sure that's my problem.
mpd2434 is offline
post #9 of 13 Old 07-07-2010, 04:14 PM Thread Starter
JWs06TJ
Thanks for the link I couldn't find 1 inch poly thats why I was asking about the metal ones by Pro-Comp. I need a full 1 inch of lift will the poly spacers compress some if so I may need a thicker one ?
JWs06TJ is offline
post #10 of 13 Old 07-07-2010, 05:10 PM
JBTJ
I've had those installed now for over 80k with no problems.
JBTJ is offline
post #11 of 13 Old 07-07-2010, 06:33 PM Thread Starter
JWs06TJ
Thanks for the reply , most seem to like the poly spacers I just dont know if they will compress more than the metal ones with the extra weight ?
JWs06TJ is offline
post #12 of 13 Old 07-08-2010, 02:19 PM
BlueFlame
BlueFlame's Avatar
They will not compress.
post #13 of 13 Old 07-08-2010, 02:48 PM
jeepinmichguy_
Soar Forever Six
jeepinmichguy_'s Avatar
x2.
ΜΟΛΩΝ ΛΑΒΕ
Jeepinmichguy is a jerk.
jeepinmichguy_ is offline
coil , pacer , lift , TJ
5 inch Pro Comp Coil Spring Conversion FlexinYJ YJ Wrangler Technical Forum 11 03-25-2016 09:11 AM
Coil Spacers or 2.5" Pro Comp Comfort Ride tpa00 JK Wrangler Technical Forum 3 06-26-2010 04:15 PM
coil spring spacers say for front or rear but coils have diameter bull346 TJ Wrangler Technical Forum 2 06-11-2009 08:26 AM
Front 3/4'' coil spring spacers,which one? jeep2008 TJ Wrangler Technical Forum 11 02-13-2009 02:26 PM
pro comp and ome coil spring q's Muddeprived TJ Wrangler Technical Forum 20 10-04-2005 10:29 AM
