Pro Answer needed. Lube 4 polyurethane bushings (I've searched.. settle the argument) - JeepForum.com
post #1 of 16 Old 07-23-2010, 08:15 PM Thread Starter
SolidBrass
My bushing replacements came (for a blown out rear upper control arm)
I've seen people say "you need special grease for polyurethane bushings" (no lube with kit)
Nobody mentions brand/specifics but some word of silicone. I asked napa and got a bit of a "uh sure that will work" answer.
I've got "premium napa wheel bearing grease and chassis" in my lube gun but bought a lithium complex grease (Amsoil synthetic).
Do I stay with what i got in all the other joints or change to this very different lube for this job and thus switch back an forth when I lube joints and take the synthetic back to the store?
SolidBrass is offline
post #2 of 16 Old 07-23-2010, 10:21 PM Thread Starter
SolidBrass
With no reply I will return the fancy grease and use the NAPA grease like the rest of them.
post #3 of 16 Old 07-23-2010, 10:59 PM Thread Starter
SolidBrass
how about some advice for pressing this into the control arm with little else but a c-clamp and retention clip pliers? My plan is large sockets to fit over metal ends and tighten with c-clamp, install retaining clip. (I'm still a virgin to every new jeep job, but really enjoying the challenge)
Thanks for all the help.
post #4 of 16 Old 07-24-2010, 02:02 AM
chmo
I think you need a synthetic silicon based grease!
Daystar has one : "Lubrathane"
Daystar KU11004 - Daystar™ Lubrathane - 3 oz Replacement Cartridge - Quadratec
silicon based with teflon ... PITA expensive AND
not available round the corner
So I was looking for replacement as well ... DuPont seems to have something but I have not seen cartridges ... only small tubes.
WHO KNOWS WHAT BRAND SILICON BASED GREASE ARE ON THE MARKET?
(This is ridiculous ... there are so many CA's with poly components inside the joints ... nobody really cares if mineral based grease is detoriating them?)
chmo is offline
post #5 of 16 Old 07-24-2010, 06:16 AM
nikeo02
I always used a lithium grease on the ones that dont have a grease fitting. Works well and lasts. If you have a grease fitting, just use reg chassis grease.
2003 Yellow TJ
nikeo02 is offline
post #6 of 16 Old 07-24-2010, 06:20 AM
DustinS
2011 JK Wrangler
I use silicone brake grease. Comes in tubs or tubes; I actually have a few cases of the mopar stuff.
And glop it on.
DustinS is offline
post #7 of 16 Old 07-24-2010, 06:59 AM
bandit455
theres a zerk on that bolt it looks like
Eagle scout jeeper #10
The Things We Make, Make Us
bandit455 is offline
post #8 of 16 Old 07-24-2010, 07:06 AM
Dissst
I use the clear silicone brake grease as well ( caliper lube ) any parts store should have it , i have heard that regular wheel bearing grease will eat at the rubber over time .
Dissst is offline
post #9 of 16 Old 07-24-2010, 07:18 AM
robncar
robncar's Avatar
Formula 5 Prelube from Energy Suspension:
Amazon.com: Energy Suspension 9.11104 Formula 5 Prelube Grease - 8 oz.: Automotive
http://www.jeepforum.com/forum/f9/diy-alignment-kit-steps-w-pics-2264465/
robncar is offline
post #10 of 16 Old 07-24-2010, 09:46 AM
mrblaine
Wizard of Brakes
mrblaine's Avatar
And glop it on.
Did you see that he's working with a JJ or a copy of one? At most, that race will hold about a quarter teaspoon of grease once it's pressed together.
All glopping it on does is waste grease and make a mess.
I am Savvy
blackmagicbrakes.com
mrblaine is online now
post #11 of 16 Old 07-24-2010, 04:09 PM
Donato_XIII
Whatever you decide on, dont over-do it. More problems can happen from overgreasing bearings/bushings then you would think.
Donato_XIII is offline
post #12 of 16 Old 07-24-2010, 08:40 PM Thread Starter
SolidBrass
Removing repairing and re-installing that upper rear control arm was more difficult than I had expected. But the job is done. Bad news is it didn't resolved my 'clunk'.
post #13 of 16 Old 07-24-2010, 09:03 PM
DustinS
2011 JK Wrangler
I was speaking in generalities more than his specific application. When I put the 3 bushing parts together in my PT cruiser control arms, it left plenty of lube room.
But I agree, overkill doesn't do much good.
DustinS is offline
post #14 of 16 Old 07-24-2010, 10:22 PM
mrblaine
Wizard of Brakes
mrblaine's Avatar
Currie JJ take about 1 ton to press them together and when you get them all assembled, there's not much room for grease. I know not of PT arms.
I am Savvy
post #15 of 16 Old 07-25-2010, 12:05 AM Thread Starter
SolidBrass
These daystar bushings were a tight fit for sure. I got a little grease on them pre-assembly but when I greased the zerk it was more or less 'air locked' i think. I got one pump in at least. Like Mr. Blaine said it allows very little grease in this assembly.
bushing , replace bushing , tj
Polyurethane bushings deepblue737 TJ Wrangler Technical Forum 20 01-19-2010 10:47 AM
holy crap, help me settle this argument!!! mike68 TJ Wrangler Technical Forum 5 02-05-2008 06:30 AM
settle an argument for me someone gixxerboy TJ Wrangler Technical Forum 3 04-20-2007 02:08 PM
polyurethane bushings? chadwickinator TJ Wrangler Technical Forum 6 06-08-2006 03:53 PM
help settle an argument Dirt_fun YJ Wrangler Technical Forum 3 03-13-2002 12:52 PM
