Prioritity? - JeepForum.com
post #1 of 6 Old 04-27-2013, 06:02 AM Thread Starter
OJack
Prioritity?
Bought an 05 LJ last year. It's in good shape, 4" lift, 33" tires etc... But I want to make it better and not sure how to prioritize, so asking your advice. It has the 6 speed and 3.73 gears. I think I would like to re-gear and add a front locker. I would like to add a winch, could have used that once already, then again if I had had the front locker, may not have needed it. I am not sure if I want to go anti-rock or disconnects. It's pretty much a daily driver... The lift is pretty basic and I would like some savvy/currie control arms, maybe new springs and new shocks. The ride is ok... I just know it could probably be better. Thoughts?
OJack is offline
post #2 of 6 Old 04-27-2013, 06:12 AM
hustler905
Do you have skids on stuff like your steering box and engine? I'd start there.
Then, wheel it a bunch and see what you're lacking.
hustler905 is offline
post #3 of 6 Old 04-27-2013, 07:27 AM
BLK00TJ
Armor > Winch > Lockers/Regear > Suspension improvement.
The locker may have helped you that one time, but more than likely would have enabled you to get into more sticky situations. If you have any inclination of locking both axles, the regear is when you want it so it will share a lot of the labor costs.
As for disconnect/anti-rock, I'd go anti-rock. Disconnects don't save as much time as you'd think. It doesn't take much more time to remove one bolt and zip-tie a link out of the way. Just make sure what you have are the correct length.
BLK00TJ is offline
post #4 of 6 Old 04-27-2013, 10:50 AM
TheBoogieman
The Devil's Advocate
TheBoogieman's Avatar
Nobody except you can answer those questions seeing that nobody here wheels with you.
TheBoogieman is offline
post #5 of 6 Old 04-27-2013, 12:20 PM
Sac2013
I would say armor & winch. Not sure what type of offroad you do, so kind of hard to make that call. But a Jeep with some armor & a winch can get you in/out of a lot of places.
2005 Wrangler X (Sold)
Sac2013 is offline
post #6 of 6 Old 04-27-2013, 02:35 PM
Anticanman
RIP one good jeeper
Anticanman's Avatar
Originally Posted by BLK00TJ View Post
Safety > Reliability > Armor > Winch > Lockers/Regear > Suspension improvement
Fify
Luck Favours The Prepared
Anticanman is offline
