powertrax no slip in rear - JeepForum.com
post #1 of 8 Old 03-28-2006, 07:50 PM Thread Starter
whitefiesta
whitefiesta's Avatar
Anyone have a powertrax no slip in the rear with a manual tranny?
i just installed mine and it acts really really strange sometimes.
stranger than any other locker ive ever witnessed.
And not typical of the no slip
it really makes the lean of the jeep noticable upon take off, sometimes it unloads when im going straight
and makes more noise than a noslip should
Originally Posted by CTLiberal
hey everyone i'm new on this sweet forum and live in Connecticut..... i bring my Jeep to construction sites and dirt roads alot so i know how to drive a jeep offroad..
Originally Posted by romperXJstomper
i got the d44 from a guy on CTliberals
Originally Posted by tealcherokee
only the retards run radius arms
whitefiesta is offline
post #2 of 8 Old 03-28-2006, 10:09 PM
Tirith
I've got the No-Slip in the rear of my 5-speed manual. And, yep, the body roll is the first thing I noticed when I picked it up from the shop. For instance, at a stop light, when the light turns green, and I put it in gear and give it throttle, the whole jeep torques slightly to one side (more so than normal). But it's not always to the same side. Sometimes it rolls to the left, sometimes to the right, and sometimes not at all. And it's obviously more pronounced with the sway bar disconnected.
It must have something to do with the way the locker engages the pinion/drivetrain. If someone has a good explanation as to what causes it, I'm all ears.
It also occasionally unloads strain on the drivetrain at odd moments, causing a snap or bang from the rear that you mentioned. But I'm told this is normal behavior from any locker. In high-traction situations (like on asphalt), when the tires need to turn at different rates, and can't because the No-Slip has not disengaged, something has to give.
So, in short, it's normal behavior, and nothing to really worry about.
However, I'll be waiting for your post after your first experience in the snow with a No-Slip.
Tirith is offline
post #3 of 8 Old 03-29-2006, 01:53 AM
UCTJ
UCTJ's Avatar
What your feeling is very typical of a lunchbox style locker. I myself would not use one in a rear application esp. on a DD, IMO your side effects are worse than my Detroit, the lunchbox lockers load and unload pretty badly in a rear axle this is the same for Lockrite. They only thing I can suggest is to just get used to it.
UCTJ is offline
post #4 of 8 Old 03-29-2006, 05:55 AM
adam728
My dad has a No Slip in the rear of his Jeep with a 5 speed, sounds like your's does, lots of loading/unloading and such.
adam728 is offline
post #5 of 8 Old 03-29-2006, 07:40 AM
bryans98tj
I have one and mine goes through the typical load/unload but it is managable unless you are driving into corners real hard. Worst part is tight parking and corners. I use the clutch alot. When I regear I am pulling mine out and selling it then putting one in the front.
-b
98 TJ-bought-not built
كافر - Infidel
bryans98tj is offline
post #6 of 8 Old 03-29-2006, 09:12 AM
jonster
jonster's Avatar
2014 JK Wrangler
Mine acted the same way. Sometimes it would sound like the rear end was breaking up and I was trying to start off with no clutch. I removed it and installed a Detroit TrueTrack. Much better till I can get a selectible locker.
2014 White JKUR
jonster is offline
post #7 of 8 Old 03-29-2006, 02:47 PM
Jgw50
I had one and never heard a peep out of it! I must have gotten lucky, I did notice the roll at start up, and if I was turning under power, it wanted to go straight a little, but very livable. Perhaps the biggest problem was the increased backlash though. Really made it hard to drive smootly at low speeds without depressing the clutch. oh well, I'm in a newer TJ now, and if yours is for a Dana 44, I'll buy it!
Jgw50 is offline
post #8 of 8 Old 03-29-2006, 04:20 PM Thread Starter
whitefiesta
if you wanna buy it in like a month
it is for a dana 44 open carrier
Powertrax No Slip in rear of DD Mattman TJ Wrangler Technical Forum 6 02-11-2010 07:18 AM
Powertrax NO-SLIP rear...how transparent? jcssurf TJ Wrangler Technical Forum 11 12-05-2008 12:05 AM
Powertrax No-Slip in d44 and d30 Tj_Justin TJ Wrangler Technical Forum 4 02-28-2007 11:26 AM
Powertrax No-Slip Front and Rear???? kcphilaflyer TJ Wrangler Technical Forum 3 12-15-2005 08:13 PM
PowerTrax No Slip Parajeeper TJ Wrangler Technical Forum 11 07-09-2002 08:45 PM
