Powertrax No - slip front 30 install ? - JeepForum.com
post #1 of 5 Old 03-03-2006, 09:31 PM Thread Starter
psl53
I have a couple of questions installing a no-slip in a front Dana 30. I have a 99 with a 3.73 so I had to pull the axles and remove the carrier. It doesn't say to put bearing grease on the bearings on either side, so I greased them anyway before putting them back. The other question I had is after removing my brake calipers and reinstalling them I put sly glide on the bolts and I always brush off where the slides contacts the caliper bracket. Should I use anti seize or sly glide which is silicone? I have had this locker for a year and was reluctant to install, it really wasn't that bad, Now on to Moab!!!!!!
Thanks
Peter
99 Sahara 4.0 6 Cyl Auto White 4.5RE ATLAS II & TW shaft, BFG 33's, Jeeperman Rear bumper tire carrier, Rokmen Rockers, Warn M8000 Powertrax no-slip in front & Rear
psl53 is offline
post #2 of 5 Old 03-03-2006, 10:45 PM
goodolboy71
Thanks
Peter
i dont think you are supposed to put bearing grease on your carrier bearings...maybe alittle lithium grease or gear oil for an install but not bearing grease..is the no slip a full carrier locker or lunch box type
93 ZJ, 4.0, np242, 4 in F>R , 33's, Arb Bumper, Warn XD 9000, Home depot Rack, lightfoce 170's and some blingy shny 5 star rims,8.8 lsd, d30 /ox locker, JCR Rock Rails
74 CJ5- total restoration from ground up, 3 spd, 304 V8, 32's
goodolboy71 is offline
post #3 of 5 Old 03-03-2006, 10:53 PM Thread Starter
psl53
It's a lunch box. Well I hope the grease will mix with the gl5 lube. Unless someone tells me it will toast the locker I'm going to leave it.
Thanks
Peter
psl53 is offline
post #4 of 5 Old 03-03-2006, 10:56 PM
nhlbill
nhlbill's Avatar
2015 JK Wrangler
If your talking about a little film of bearing grease on your carrier bearings, there is nothing wrong with that, The gear oil will break down the bearing grease anyway once it has been run for a while.
You are not supposed to "pack" the carrier bearings though like you would a wheel bearing. Although I don't think it would hurt it, and the grease would eventually break down in the gear oil after time.
IMO If you did "pack" them, be sure to change your gear oil after 500 or so miles.
I prefer to use an Anti seize on the caliper bolts and slides.
Bill
Gone but not forgotten:
05 TJ Sport
RK 5.5" Long Arm, 1" Daystar BL
M.O.R.E. Bombproof 1" MML
AA SYE, RE CV Driveshaft
4.56's, ARB Super 30 Front, Detroit D44 w/Alloys Rear
35" BFG MT's
RK X-Factor steering, Currie Anti-Rock,
Nth oil pan skid, Rock Crusher Diff covers
Line X
OBA (Viair 450c System)
Trail Gear Rockers
Custom rear bumper/swing out
nhlbill is offline
post #5 of 5 Old 03-04-2006, 06:06 AM Thread Starter
psl53
Thanks NhlBill,
That's exactly what I did. I didn't pack them at all, just spread a little grease to get things back together. Thanks for the help.
Peter
psl53 is offline
Powertrax Dana30 No slip install/write up barry1me TJ Wrangler Technical Forum 52 12-01-2011 11:40 AM
Powertrax locker install. 8.8 limited slip Axl Jack YJ Wrangler Technical Forum 31 04-11-2010 05:41 PM
Dana 30/powertrax no-slip install problem JeepinSC87 YJ Wrangler Technical Forum 2 01-09-2010 11:04 AM
Front Powertrax No Slip WilliamH TJ Wrangler Technical Forum 9 03-16-2007 11:47 AM
write-ups for powertrax no-slip/lockright install D30/D44 kcphilaflyer TJ Wrangler Technical Forum 3 03-17-2006 11:54 AM
