Powertrax Dana30 No slip install/write up - Page 4 - JeepForum.com
post #46 of 53 Old 02-15-2011, 04:12 PM
2GPS4ME
Originally Posted by RowJ View Post
Do they tear up the 27 splines, or snap somewhere on the shaft?
From looking at carnage pictures, they usually snap close to the neck where the splines end.
What I'm really asking is will the a locker and 33" tires be Ok on a D35 with Superior 27 spline shafts?
I know of 2 TJs that ran lock-rights on stock D35s, and they were fine. I'm sure the Superior shafts will hold up well (to easy-moderade use, no trail bashing).
Thought I read to stay with 27 splines and be able to use factorys as spares??
That sounds like an economical and reasonable approach to me. Superior shafts are $99 on Morris 4x4.
WJ (WIFE JEEP) PROJECT COMING SOON
2GPS4ME is offline
post #47 of 53 Old 09-22-2011, 11:59 PM
ytowntj
I think you would be fine with the superior shafts as long as you stick to 33s.
Interestingly enough, based solely on cross section area and the yield stress differences, a 27 spline 4340 superior evo shaft is about the same strength as a stock d44 shaft.
If anything, I would think you would break the stock carrier or damage the housing itself.
Edit: Holy cow, Just realized this is an old as dirt thread. how did that happen?
ytowntj is offline
post #48 of 53 Old 09-23-2011, 10:36 AM
TJinSoFLA
I still have questions about a the no-slip. In a front HP D30, will the front stock axles snap when the locker engages while trailing on 33's? Also, is it absolutely necessary to remove the carriers in the d30 and rear d44 w/ trak-lok carrier?
TJinSoFLA is offline
post #49 of 53 Old 10-14-2011, 02:44 AM
hmd100100
Junior Member
I have the same question above:
Do I have to remove the carrier when installing the No-slip locker in the front D30 axle?
I have a 2000 XJ with 3.55 d30 front axle.
hmd100100 is offline
post #50 of 53 Old 11-06-2011, 09:14 PM
Brazos609
I think so.
Brazos609 is offline
post #51 of 53 Old 11-22-2011, 07:50 AM
david63
Hi All,
Great Thread!
Although not a Jeep question, I hope you can help out.
If I install a locker in my 1991 Mercury Grand Marquis (I think it has 8.8"/28 spline diff) will I break my stock axles?
Thanks for any advice
DW
david63 is offline
post #52 of 53 Old 11-22-2011, 02:11 PM
2006_Sport
Pry bar probably wasn't the best way to remove the carrier but to each his own. Good write up. Eventually I'll go with a no slip in the rear as I don't feel like replacing the aussie up front . Those springs are beefy as hell.
2006_Sport is offline
post #53 of 53 Old 12-01-2011, 12:40 PM
ChaseB
Looking to get a locker for my front 30...Seems like powertrax is the way to go
1984 CJ-7 Renegade
2005 TJ X (daily driver)
ChaseB is offline
Powertrax locker install. 8.8 limited slip Axl Jack YJ Wrangler Technical Forum 31 04-11-2010 06:41 PM
Dana 30/powertrax no-slip install problem JeepinSC87 YJ Wrangler Technical Forum 2 01-09-2010 12:04 PM
write-ups for powertrax no-slip/lockright install D30/D44 kcphilaflyer TJ Wrangler Technical Forum 3 03-17-2006 12:54 PM
Powertrax No - slip front 30 install ? psl53 TJ Wrangler Technical Forum 4 03-04-2006 07:06 AM
PowerTrax No Slip Parajeeper TJ Wrangler Technical Forum 11 07-09-2002 09:45 PM
