Powertrax Dana30 No slip install/write up - Page 3 - JeepForum.com
post #31 of 53 Old 12-13-2009, 06:40 AM
Howland
[/QUOTE]
haha, i see your Autozone commercial customer driver slips on the clipboard.
Nice write up, thanks for the pictures
Howland is offline
post #32 of 53 Old 12-19-2009, 03:44 PM
BriansCJ
1994 XJ Cherokee
Do you have to reset the backlash with this.
- Daily Driver & Weekend Wheeler
- Slow
BriansCJ is offline
post #33 of 53 Old 12-19-2009, 03:47 PM
Jerry Bransford
Administrator
Jerry Bransford's Avatar
Reinstall the shims exactly as they came out and there is no need to worry about the backlash if it was correct to begin with.
Jerry Bransford is offline
post #34 of 53 Old 12-19-2009, 06:06 PM
BriansCJ
1994 XJ Cherokee
Thanks Jerry.
- Slow
BriansCJ is offline
post #35 of 53 Old 01-05-2010, 10:45 AM
MC_NickP
i have a dana 35 c clip model with the powertrax lock right locker. i jsut put the locker in. does this mean i am just waiting for my axle to implode?
Black 98 TJ
Low Output 4 Cylinder Jeep Club #178
build thread:
MC_NickP is offline
post #36 of 53 Old 01-21-2010, 09:29 AM
Painbow6
There's a couple questions that went unanswered in this thread and I was wondering the same kinds of things.
1. What is the difference between the Lock Right and No-Slip? I thought the No-Slip was a limited slip-like product while the Lock Right is an auto locker. But this whole business of no clutches and %100 lock up for the No-Slip makes me wonder...
2. How does the No-Slip handle up front in the snow/ice?
Painbow6 is offline
post #37 of 53 Old 01-21-2010, 09:43 AM
Jerry Bransford
Administrator
I certainly would not have installed that locker if it were my Dana 35c axle. Their axle shafts can break with bigger tires even without a locker but with a locker it's only a matter of time.
post #38 of 53 Old 01-28-2010, 07:16 PM
FL_Curb_Crawler
I just ordered my lock right locker tonight. The install has me worried but this thread has helped me put my mind at ease a little.
FL_Curb_Crawler is offline
post #39 of 53 Old 02-01-2010, 06:04 PM
grogie
M-F: Cell Block #4533
grogie's Avatar
Originally Posted by rpiereck View Post
Since you are in Michigan, how did the Powertrax do in the snow and ice? I want to add one to my Dana 30 front but I'm not going to do it if during the winter the Jeep is a hazard. For almost six months of the year my driveway is icy...
X2 (or X3 actually), how is it on roads with ice and snow?
Red Jeep Club #345
2006 TJ Sport -
2004 KJ Limited
2013 Off-Road Trailer -
from the onslaught of young idealists. -- Don Colacho
grogie is offline
post #40 of 53 Old 02-01-2010, 06:15 PM
Jerry Bransford
Administrator
Keep it in 2wd when it's icy & it will be fine. Shifting into 4x4 will lock the front locker up hard enough that it will cause understeer during a turn on an icy or otherwise slick surface.
post #41 of 53 Old 02-20-2010, 09:45 PM
2GPS4ME
Thanks for the insight, Jerry. I was a couple clicks away from ordering a Powertrax for my D35....
Narrow Road Jeep Garage
Owner, Operator
2GPS4ME is offline
post #42 of 53 Old 02-20-2010, 10:21 PM
evan1395
would this locker be ideal for my 02 TJ, i wanna put a noclip in my D35 rear end, only cuz powertrax is the only differential company that makes lockers for my Trak loc Carrier. i got stock axle shafts and 33's. and a real light foot no matter what i wheel
evan1395 is offline
post #43 of 53 Old 06-16-2010, 10:16 PM
andyroos
Help - I think I made a boo-boo with my locker install
I read in this thread -
make sure to note the original location of the carrier and ring gear. I used a zip tie on both the carrier and the ring to make sure that the ring gear didnt get clocked.
What happens if my carrier and ring "got clocked"?
Also what should be the torque spec for the unit bearings and ring gear?
andyroos is offline
post #44 of 53 Old 06-16-2010, 10:48 PM
rkwfxd
Nothing - it will work fine.
rkwfxd is offline
post #45 of 53 Old 02-15-2011, 01:39 PM
RowJ
Not clear on one thing.
Do they tear up the 27 splines, or snap somewhere on the shaft?
What I'm relly asking is will the a locker and 33" tires be Ok on a D35 with Superior 27 spline shafts?
Thought I read to stay with 27 splines and be able to use factorys as spares??
RJ
RowJ is offline
Powertrax locker install. 8.8 limited slip Axl Jack YJ Wrangler Technical Forum 31 04-11-2010 05:41 PM
Dana 30/powertrax no-slip install problem JeepinSC87 YJ Wrangler Technical Forum 2 01-09-2010 11:04 AM
write-ups for powertrax no-slip/lockright install D30/D44 kcphilaflyer TJ Wrangler Technical Forum 3 03-17-2006 11:54 AM
Powertrax No - slip front 30 install ? psl53 TJ Wrangler Technical Forum 4 03-04-2006 06:06 AM
PowerTrax No Slip Parajeeper TJ Wrangler Technical Forum 11 07-09-2002 08:45 PM
