Quantcast Power Steering Pump Pulley Noise - JeepForum.com
Go Back JeepForum.com > Models > Jeep Wrangler Forums > TJ Wrangler Technical Forum > Power Steering Pump Pulley Noise
GR8TOPS Introduces the Exogate HD Tire CarrierTruck-Lite's New LED Headlamp SeriesRUBICON EXPRESS Lift Kits and Accessories Available at Bas
Old 07-18-2008, 12:57 PM   #1
brrempel
My power steering pump pulley makes a squealing noise when I start my Jeep and it stops once the engine is up to operating temp. I looked in my factory service manual to see if there is some way to lube it, but found nothing. Is there something I'm missing? If I can't lube it, will I need to rebuild or repair the pump in order to stop this noise?
Brian
brrempel is offline   Reply With Quote
Old 07-18-2008, 03:06 PM   #2
TheBoogieman
Demonic Jeep Freak!
TheBoogieman's Avatar
Are you sure it's the pulley?Mine did that and it was the belt.
TheBoogieman is offline   Reply With Quote
Old 07-18-2008, 04:08 PM   #3
brrempel
Well, it's possible it's the belt, but the belt is only a few years old and shows no signs of needing replacement, except maybe this squealing sound.......
The belt is by far the easiest and cheapest component to replace so I guess I'll start with that. Something to do this weekend I guess.
Brian
Old 07-18-2008, 04:14 PM   #4
OldFatGuy
Are you even sure it's coming from the power steering? The alternator would be a more likely source. Is your belt tension adjustable or does it use a spring tensioner?
OldFatGuy is offline   Reply With Quote
Old 07-18-2008, 04:24 PM   #5
brrempel
It's for sure not coming from the alternator. It's adjustable, but I've played with it and can't get it to stop, or even change in volume or intensity for that matter. However, once the engine is at normal operating temp it stops making the noise.
Brian
Old 07-18-2008, 10:14 PM   #6
halfmoonclip
Our 99XJ had this issue; da' kid comes in complaining that her pulleys were squealing when the air was first on.
Actually changed out the power steering pump for the same problem, and it didn't solve it.
I tightened the idler pulley with the bolt on the power steering bracket; seems to help, but get it too tight and it will take out the water pump bearing.
Moon
'04 Rubi, manual, usual options, Hella H-4s, any range lockers, Randy's booster seats, Oly pushbar, 245/75R16 BFG
'09 Audi A4 Avant- my bride's schnellpuffenpanzer
'12 Ford Focus-the sure way to get good Jeep mileage
'07 Dodge Caliber R/T AWD-da kid's ride
Goodbye Old Blue XJ; 10+yrs, 100K+ miles; virtually trouble free; Long may you run!
halfmoonclip is offline   Reply With Quote
Glock Forum
