Quantcast power steering pump pulley - JeepForum.com
Go Back JeepForum.com > Models > Jeep Wrangler Forums > TJ Wrangler Technical Forum > power steering pump pulley
Old 01-24-2009, 01:52 AM   #1
GreenTJ420
changed my power steering pump on my TJ this week, after getting two bad rebuilds got a good one on the third try. my question is when i was putting the pulley on the third one got to almost flush with shaft and stopped just shy of being flush. the only thing i can tell so far is that belt runs a little off on the idler pulley below, not alot but about _ that distance from the back of pulley. probably not even that far out, just the only way to demonstrate distance. will this cause problems or is it fine, cause i broke two bolts and ripped my vice off the table trying to push this pulley on. other two bad pumps got to sit flush but not this one. any help would be cool. also what is a cheap place to buy a all metal radiator at. thanks
GreenTJ420 is offline   Reply With Quote
Old 01-24-2009, 07:52 PM   #2
GreenTJ420
anyone know anything about this?
Old 01-25-2009, 07:47 PM   #3
GreenTJ420
no one really?
Old 01-25-2009, 07:50 PM   #4
GREASEMONKEY
GREASEMONKEY's Avatar
Sounds like you need a PULLEY INSTALLER/REMOVER TOOL
http://www.sjdiscounttools.com/kd2897.html
MY VID'S
My Rear Bumper - Tire Carrier
My Front Bumper/Stinger
My Ammo Can Console
Friendship is like peeing on yourself: everyone can see it, but only you get the warm feeling that it brings.
GREASEMONKEY is offline   Reply With Quote
Old 01-26-2009, 12:14 PM   #5
GreenTJ420
i bought 3 of those kits with the bolt and washer system. those are the bolts that i snapped in half or bent the snot out of and ripped one of the mounting bolts from my vice. wanted to know if it has to be flushed or not, cause if it does i have to buy another pulley, cause the one thats on it if i try anymore will break. thanks
Old 01-27-2009, 12:36 AM   #6
GREASEMONKEY
Yes it should sit flush. The belt should be riding the serpentine pulley system about dead straight.
Unless the puley is damaged, I don't see a reason to replace it. I have this problem all the time. Pull the pulley off, take a peice of emery cloth and polish the pump shaft a bit, spray some decent lube on the shaft 7 pulley hub, and reinstall! Not all pump shafts are perfect, and sometimes need a little tweak!
MY VID'S
My Ammo Can Console
Old 01-27-2009, 01:04 AM   #7
Baggot
This wont help you put it on yourself but is a good option none the less.
Rent one from checkers you pay 35$ or retail to use it and then you return it and they give your 35$ back. I had success with the remover but couldnt get the installer to put it back in because the threads pulled off (piece of junk). Got my $ back and i went to napa and they installed it for me in 10 minutes and charged me 6$. I wasted about an hour with that stupid installer tool should have just gone to napa first. Thank goodness I didnt have to buy that crappy tool. sorry to hear you bought 3.
Baggot is offline   Reply With Quote
Old 01-27-2009, 01:27 AM   #8
GREASEMONKEY
If you got the KD brand I posted up, then it has a lifetime warranty. You just take the broken part of the set back, and they get ya a new one. I keepthat set at home for use on my cars. I keep my Snapon set at work.
MY VID'S
My Ammo Can Console
Old 01-27-2009, 02:03 AM   #9
GreenTJ420
thanks for all the help guys, let ya know in a couple of days how it went. didn't get that brand just some kit from autozone was cheap so not out a lot of money, just patience. ha.
Old 01-27-2009, 08:23 AM   #10
mrblaine
Brake Wizard
mrblaine's Avatar
Agreed 100 percent. I have the KD brand and have removed and installed at least 20 pulleys with it.
I am Savvy
I am handling the sales of Black Magic Brakes on www.blackmagicbrakes.com
mrblaine is offline   Reply With Quote
Old 02-09-2009, 01:16 PM   #11
GreenTJ420
well got everything fixed finally, it only took four rebuilt pumps that i went through till i finally broke down and bought a new one from jeep. moral of the story don't but rebuilt power steering pumps from any parts store. got one from every different store and they all leaked.
Old 02-11-2009, 10:00 AM   #12
GREASEMONKEY
That's good to hear you got it all worked out. It's just luck when it comes to PS pumps. I have been rollin around on a rebuilt unit from autozone, about 2yrs now. When my OE pump died the autozone store was nearby, and had one on the shelf. I have just never spent the time to replace it again.
MY VID'S
My Ammo Can Console
Old 02-14-2009, 09:24 PM   #13
GreenTJ420
Update on everything going total 5 pumps and 6 days of wrenching. The first 4 pumps were all bad from 4 differnt stores either leaked from differnt spots or couldn't get the pulley on all the way. Finally broke down and bought a brandnew one, 6 days and evrything still good. Next radiator and lift. Just relaized that I said the same stuff^^ up there. That's what you get for doing this at work
Glock Forum
