Power Steering Noise - JeepForum.com
Go Back JeepForum.com > Models > Jeep Wrangler Forums > TJ Wrangler Technical Forum > Power Steering Noise
The Original 3/8" Ruffstuff Diff Cover!Ruffstuff Axle Simple Swap Kit!The Ruffstuff NOT Universal 4 Link Kit!
Unread 04-12-2004, 08:11 AM   #1
DirtyRedTJ
I have fried my power steering on the trails. It makes a terrible whine and gets very hard to turn. I changed the fluid and added some lucas ps additive in hopes of a quick fix, but that didn't help. I'm not sure if its the pump or the gear box. I'm sure some of you fellow Jeepers have had the same problem. I need to fix it, but I need help knowing what to replace. I will also be adding a ps cooler whit the new parts.
Thanks
[COLOR=darkred]You Gotta Hit It Harder Than That![/COLOR]
1998 SE, 4 Gerbils , 5 speed,
D30 Front, Diff Guards, QD's,
3" Black Diamond springs, Rough Country LCAs,
Pro Comp es3000's, 2" bl, 8,000lb winch,
TB spacer, K&N, Electric Fan, hand throttle,
CB, Seat covers, chopped bumper,
33 x 12.50 Truxus MTs, AR wheels,
Rocker guards, Lights, High Lift ...
[COLOR=darkred]Certain Death Jeep Club Member #2[ /COLOR]
2002 WJ 31x11x16 Thornbirds, Westin Safari Bar
DirtyRedTJ is offline   Reply With Quote Quick reply to this message
