Power steering gearbox - JeepForum.com
post #1 of 9 Old 04-21-2008, 12:52 PM Thread Starter
Piratejonh
Piratejonh's Avatar
My power steering gear box is leaking at the pitman arm/lower end. Does anyone have the upgraded steering box? Is it worth the price as opposed to an OEM rebuilt unit? My jeep is a mud runner-no rocks in florida.
Jeep took another piece of my finger today...
Piratejonh is offline
post #2 of 9 Old 04-21-2008, 12:54 PM
Big_Fisch
For now, I used Lucas Oil power steering stop-leak. To my surprise, it ACTUALLY worked incredibly. Obviously not a permanent fix, but it will most likely bide you some time.
Big_Fisch is offline
post #3 of 9 Old 04-21-2008, 01:40 PM
Jeepin' Rock Cl
There are replacement seal kits from the deal that aren't too expensive. However, if you want to look at this as an opportunity to upgrade, a steering box from a Durango with snow plow package will bolt on and is much stronger.
Jeepin' Rock Cl is offline
post #4 of 9 Old 04-21-2008, 01:51 PM
jb4
I finally got the rebuilt trans from Tellico back in my jeep this weekend, so its the first time I've driven it in the 4 months I've owned it. went to turn around in my cul-de-sac and had no power steering. checked the reservoir - it was bone dry, so I filled up the fluid cranked the wheel lock-to-lock fifty times and started it up. Power steering fluid began pooring out of the gear box seal and the pump
I've ordered a 98 Durango box from Napa, new hoses, a pump and a V-Belt. I'll take pics when i put it all in.
from what I've read the difference in the Durango box is that the interior gear set is a bit beefier than the stock one and the difference between the two Durango boxes (w. plow or w.o plow) is the number of turns on lock-to-lock
the one without the plow is closest to the jeep.
jb4 is offline
post #5 of 9 Old 04-21-2008, 06:19 PM Thread Starter
Piratejonh
Piratejonh's Avatar
Thank you all for the info so far. Im going to look into the durango gearbox. jb4 you mentioned ordering a v-belt? I use a serpantine belt on the wrangler. I was also hoping to hear from someone who has installed the AGR gear boxes and pumps. It seems they are almost the same price as a new oem one.
post #6 of 9 Old 04-21-2008, 06:46 PM
Rigged
I have a PSC Steering Box. It was a definite improvement over stock. It is a bit expensive, but worth it. Now that I have larger tires it feels like I have 29's on there it's great. I going to be looking into the PSC Pump and Reservoir pretty soon.
http://www.pscmotorsports.com/
-Kyle
Rigged is offline
post #7 of 9 Old 04-21-2008, 07:22 PM
jb4
I'm sorry, force of habit. 'v belt' is meant to mean 'serpentine belt'.
jb4 is offline
post #8 of 9 Old 04-21-2008, 08:09 PM
clintsharley
So... with the durango gearbox, it just bolts up, but is the durango power steering pump needed? Or is my factory tj pump good to use with that gearbox? Thanks
Last edited by clintsharley; 04-21-2008 at 08:10 PM. Reason: typing to damn fast... who would of thought
clintsharley is offline
post #9 of 9 Old 04-21-2008, 08:36 PM
bdf1783
ive got an agr box wooks great,good improvement i would deff recomend it, if u get it the only thing i recomend is u throw some clear coat on it mine started to get surface rust first time it got wet
00 tj 4.0
4'' teraflex lift 33'' wrangler mtr 1'' bl 1''bd mml borla header and cat-back, arb snorkel warn 9000 tera belly up, poison spyder rocksliders modular night crawler frnt bumber oro u turn steering system agr steering box 2
bdf1783 is offline
Power Steering GearBox Ports Samuel1115 YJ Wrangler Technical Forum 5 12-08-2009 08:18 PM
Bad power steering pump or gearbox? YJTJlover YJ Wrangler Technical Forum 9 10-20-2008 03:46 PM
Where to buy a good power steering gearbox? drew2000 YJ Wrangler Technical Forum 6 08-13-2008 04:57 PM
Power Steering Gearbox jake7893 TJ Wrangler Technical Forum 0 06-24-2007 07:32 AM
Power Steering Gearbox davidc2000 TJ Wrangler Technical Forum 4 08-03-2004 07:52 AM
