Power Steering Fluid w/Burnt Smell - JeepForum.com
Go Back JeepForum.com > Models > Jeep Wrangler Forums > TJ Wrangler Technical Forum > Power Steering Fluid w/Burnt Smell
Introducing MONSTALINER™ UV Permanent DIY Roll On Bed LineRaceline/Allied Wheels on Sale NOW !Bead Lock Wheels! Raceline, Trail Ready, & Trail-Gear
Unread 01-16-2007, 08:32 PM   #1
Ivan
About a months ago I checked my power steering fluid and discovered it below the dipstick level. What was there was dark brown (like old coffee) and had a strong 'burnt oil' smell.
Filled to the cold level with an after market fluid and a week later sucked out all the oil in the reservoir and refilled w/Mopar power steering fluid (it has a clear color).
Now 3 weeks later and the oil is light brown (tea colored) and has a slight 'burnt oil' smell.
Have good steering so know the 'power' is there, but don't understand the quickly darkening fluid color and 'burnt' smell. Any ideas????? Is this 'normal'?
There are no leaks from the pump. reservoir, lines or steering box. Fluid level stays to the mark - Just baffled by the rapid discoloration and smell 3 weeks after changing the fluid in the reservoir.
[center]One of the 1,993 [COLOR="Yellow"]Golden Eagles [/COLOR]produced in 2006.[/center]
[CENTER][URL="http://www.jeepforum.com/forum/showthread.php?t=32021"][COLOR="Blue"]Blue Jeep Club Member #228[/color][/URL][/CENTER]
Ivan is offline   Reply With Quote
Unread 01-16-2007, 08:39 PM   #2
bobbert350
well id say the reason its light brown is that it mixed with the other fluid that was in there since you didnt flush the power steering fluid out b4 you added new stuff it just mixed with the old and changed colors
88 jeep wrangler, 4.2, auto---cragar soft 8's, d35 locker, bucket seats with 5 point harnesses, warn bumper w/ grill gaurd, winch plate, kc daylighters, light bar, herc the interrior, rebuilt tranny (yay) with tranny cooler, winch and msd ignition, 3.5 inch fabtech lift, currie boomerang shackles f/r, weber carb...[B]
[B]Why only go anywere fast when you can go anywhere[/B]
bobbert350 is offline   Reply With Quote
