Power Steering Fluid - JeepForum.com
post #1 of 6 Old 11-04-2004, 11:12 PM Thread Starter
Dragonmaster
Dragonmaster's Avatar
What type of power steering fluid is called for? Users manual was stolen and my fsm in is my parents garage about 60 miles away. Pumps been squeelin and the fluid is low.
Thanks.
2002 Jeep TJ SE 2.5L
Sienna Pearl, dual tops, tan interior, 31x10.5's,
1" Rubi Spring lift (yes it does boost an SE 1", ask me how I know)
Work 2 Live, Live 2 Play, Play = JEEP
Dragonmaster is offline
post #2 of 6 Old 11-04-2004, 11:39 PM
jrtdogbone
jrtdogbone's Avatar
Power steering fluid
Thanks.
I have a 2004 TJ. The owners manual says mopar automatic transmission fluid. My 2002 Grand Cherokee owners manual says mopar power steering fluid.
Good Luck
The Dog
The Dog
2004 Jeep Willys
jrtdogbone is offline
post #3 of 6 Old 11-05-2004, 09:25 AM
rokrover
Yep, be careful as the 2004's specify Mopar ATF+4 ONLY (the red stuff). At some point after the 2002 model year this changed from the usual Mopar Power steering fluid (brown) as the previous post pointed out. Not sure why the change.
rokrover is offline
post #4 of 6 Old 11-05-2004, 10:02 AM
wrangler2002
Chrysler sent out a TSB a while back to switch (I think) 2000 models and up to ATF from power steering fluid. I think the reason was the power steering fluid had some performance issues in very cold weather. It was a bit too thick for the pump...
wrangler2002 is offline
post #5 of 6 Old 11-05-2004, 10:23 AM
04 Unlimited
04 Unlimited's Avatar
2015 JK Wrangler
Chrysler issued a Power Steering TSB # 19-005-03, dated Aug. 29, 2003 directed to this issue. Your '02 TJ originally had MS5931 PS fluid. According to the TSB, this MS5931 fluid is the one to use to top off as well. The part number for MS5931 is 04883077 (quart).
Hope this helps,
Rich
04 Unlimited is offline
post #6 of 6 Old 11-05-2004, 11:04 AM
Jerry Bransford
Administrator
Jerry Bransford's Avatar
When I install my new power steering cooler sometime in the next few weeks, I'll be switching to Valvoline's synthetic power steering fluid. I've read and heard nothing but praise for its ability to withstand hot PS fluid temps better like we get on some of our local desert tight-twisty trails.
I am not sure that it is compatible with regular PS fluid so I can't recommend it unless you plan to completely drain the PS system like I'll be doing.
Getting
Jerry Bransford is offline
Power Steering Fluid (Miniscule) Leak from Steering Column??? JRostron30 TJ Wrangler Technical Forum 3 07-10-2009 12:20 AM
power steering fluid plyguitar45 YJ Wrangler Technical Forum 2 02-16-2009 06:40 PM
Power steering fluid everywhere jgreeno TJ Wrangler Technical Forum 2 12-10-2008 06:14 PM
Power Steering Fluid TJShadow TJ Wrangler Technical Forum 8 11-24-2008 12:44 PM
Power steering fluid OlllllllO Jeep1 YJ Wrangler Technical Forum 3 04-10-2005 10:07 AM
