Power Outlet / Cigarette Lighter not working - JeepForum.com
post #1 of 7 Old 04-04-2012, 11:13 AM Thread Starter
2005-TJ
1983 CJ7
My power outlet and cigarette lighter are not working in my 05 TJ...I check the fuse and it has power and they are both plugged in. Any ideas?
2005-TJ is offline
post #2 of 7 Old 04-04-2012, 11:14 AM
mdm
Farm Wheeler
Ground? Are you getting power to the outlet?
Keep in mind that free advice can frequently be worth less than you pay for it.
mdm is offline
post #3 of 7 Old 04-04-2012, 11:28 AM Thread Starter
2005-TJ
1983 CJ7
i only checked the fuse behind the glove box but after reading some posts on here, it looks like there may be 2 others under the hood to also check
2005-TJ is offline
post #4 of 7 Old 04-04-2012, 12:44 PM
Rubi4MyMrs
Rubi4MyMrs's Avatar
They are on separate fuses. Power outlet fuse 17 (PDC under hood). cig lighter fuse 18 in block behind glove box. The power outlet has battery power, the lighter only with key on/acc. Make sure the black wires are grounded.
Rubi4MyMrs is online now
post #5 of 7 Old 04-04-2012, 12:50 PM Thread Starter
2005-TJ
1983 CJ7
thanks...i will check that out when i get home tonight
2005-TJ is offline
post #6 of 7 Old 04-05-2012, 07:11 AM Thread Starter
2005-TJ
1983 CJ7
I found a blown 20 amp power fuse in the fuse box under the hood...replaced it and now my power outlet works but cigarette lighter still doesn't. I looked inside it and the contacts are very rusty. Gonna try to clean the contacts today with some sand paper and see if it works.
2005-TJ is offline
post #7 of 7 Old 04-05-2012, 08:07 AM
jLowrey83
I had a similar issue with mine. I actually just spun my phone charger around in there repeatedly until the LED(on the charger) stayed on. Guess it was corroded
-Sgt "Jake" Williams USMC/0311 OIF '05-
jLowrey83 is offline
No Power to the cigarette lighter? I need it for my GPS... rgingerelli99tj TJ Wrangler Technical Forum 28 07-06-2012 02:14 PM
Auxiliary(cigarette lighter) isnt working... colton908 TJ Wrangler Technical Forum 2 12-11-2011 08:39 AM
TJ Cigarette Lighter and 12v Power Outlet YellowX TJ Wrangler Technical Forum 12 10-13-2010 05:51 AM
cigarette lighter and unswitched fuse stopped working Grants99TJ TJ Wrangler Technical Forum 6 08-29-2010 05:14 PM
Cigarette Lighter stopped working chuckda4th TJ Wrangler Technical Forum 1 01-24-2005 09:45 PM
