Power distribution fuse 19 - JeepForum.com
post #1 of 2 Old 09-10-2007, 01:08 PM Thread Starter
'51plymouth
1995 XJ Cherokee
What is it? I'm assuming it has something to do with the horn, but why does it keep blowing (the fuse, not the horn--THAT doesn't make a peep, ever). What has gone bad this time? Horn relay is my first guess, but does anyone here have some first-hand knowledge? Getting tired of chasing electrical gremlins...
BTW--it's NOT the clock spring, that was just replaced and all fault codes have vanished, along with the airbag/check engine lights and my terrible rough idle/stumble.
Thanks,
Jack
'51plymouth is offline
post #2 of 2 Old 09-11-2007, 06:36 AM Thread Starter
'51plymouth
1995 XJ Cherokee
Just to clarify, it is not the relay, as I have replaced that since my last post. The fuse, #19, is fine and does not blow until I press the horn button. As soon as the horn button is pressed, no horn--the fuse blows instead. Any ideas?
help with my 97 TJ Power Distribution Center firefly TJ Wrangler Technical Forum 2 11-06-2009 10:08 PM
WHere is the power distribution center? rocknroller89 YJ Wrangler Technical Forum 8 06-16-2009 11:15 PM
Power Distribution Location Jeebs YJ Wrangler Technical Forum 5 05-25-2008 11:17 PM
Power Distribution Center Failure wyomingyj YJ Wrangler Technical Forum 0 04-08-2008 08:59 AM
Power Distribution Center Ferrick YJ Wrangler Technical Forum 5 02-21-2008 03:15 PM
