Potentially Dumb Question - BB and SL together? - JeepForum.com
post #1 of 28 Old 04-26-2013, 08:16 PM Thread Starter
yoshi280zx
Hey, all.
I've searched the forum, but can't seem to find anything on this. Please forgive me if this is a totally stupid question.
We all know people install body lifts and suspension lifts together all the time.
I currently have a 2" budget boost on my TJ. The time has come to replace suspension parts, bushings, etc. and I thought this would be a good time to go a little higher. Can you install a suspension lift and budget boost together? Has anyone tried this before? I know the motor mounts, t-case and other things might need to be moved around, but was wondering if this is ever really done...
Thanks!
James Johnson
1997 Jeep TJ Sport -
1998 Dodge 3500 12V -
1980 280ZX AE -
Follow me on Twitter! @johnsonjamesy
yoshi280zx is offline
post #2 of 28 Old 04-26-2013, 08:17 PM
afusco1222
Yeah you can do it.
afusco1222 is offline
post #3 of 28 Old 04-26-2013, 08:19 PM
Unlimited04
This post/info=my opinion
Unlimited04's Avatar
you can, it's just a stupid idea.
Useful Write-Ups:
Fabrication & Build:
Funny:
Unlimited04 is offline
post #4 of 28 Old 04-26-2013, 08:20 PM
wwch99tj
I wouldn't stack the 2" BB on the new springs, if you're going to buy new springs buy the size lift you want...
Some stack a .75" spacer on top of lift spring to level the front out after a heavy bumper and winch...
Sent from my Samsung Galaxy S3 using JeepForum
wwch99tj is offline
post #5 of 28 Old 04-26-2013, 08:36 PM
McLovin
Please enlighten us as to why you think it is a stupid idea?
Why wouldn't you do it?
I have 4 new zone hydro shocks for sale...PM for a price.
McLovin is offline
post #6 of 28 Old 04-26-2013, 08:53 PM
Unlimited04
coil length & spring rate issue, coil bind, requires extra bumpstop extension resulting in loss in uptravel, requires longer shocks, to name a few things. basically, if you understand how suspensions work, it's pretty self explanatory.
Useful Write-Ups:
Funny:
post #7 of 28 Old 04-26-2013, 09:10 PM
McLovin
A puck on top of a spring does NOT affect the spring rate. The spring rate is determined in the manufacturing process.
Bump stop extension is determined by the amount of lift and tire size, it doesn't matter if the lift is achieved via a puck or a spring.
Shock length would need to be dealt with regardless of if he did 4" springs or 2" springs and 2" pucks.
Coil bind is not an issue with 2" pucks.
Your right, the answer is pretty self explanatory if you understand suspension systems and how they work.
To the OP yes you can absolutely put 2" springs under 2" spacers, just keep in mind it is now a 4" lift and you will need the same components regardless of how you get your lift(straight spring or puck and spring). I like many people started out with a budget boost, then wanted bigger and added a bodylift, then came across a great deal on some OME springs, I ran them under the pucks for 2 years. I jumped, ran the whoops, mudded, was generally very hard on things. I had zero issues. I have friends that set up their TJ's in a similar way and it worked for them as well.
McLovin is offline
post #8 of 28 Old 04-26-2013, 09:31 PM
Unlimited04
i'm well aware of that. but sticking a 2" puck on top of a soft 2" spring doesn't fix the root problem of the heavy winch & bumper someone added. springs of the proper rate and length do fix that problem.
there are a whole bunch more factors than just tire size.....and lift height has nothing to do with it.
it absolutely is. that's the problem.
too bad you don't understand how they work
Useful Write-Ups:
Funny:
post #9 of 28 Old 04-26-2013, 10:07 PM
McLovin
What does that have to do with the above post? Answer: nothing! He is just wanting to go bigger.
I have been working on TJ's since they came out, I can tell you with 100% certainty that Coil bind is not an issue on 2" or smaller pucks.
obviously
McLovin is offline
post #10 of 28 Old 04-27-2013, 04:55 AM
wwch99tj
I wouldn't do it because if I was going bigger I would just get the length springs I wanted instead of stacking the 2" BB back on top...
Op:
if you are buying a new lift just get the size lift you want to run and forget the BB... just my opinion tho.
wwch99tj is offline
post #11 of 28 Old 04-27-2013, 05:37 AM
99_TJ_Wyoming
Yes you can, and it's done quite regularly, the RC 3.25" lift consists of 2.5" springs with .75" spacers and it works very well. There is nothing wrong with it, it doesnt hurt springs or other components.
All that being said, if you have a 2" BB and your getting a suspension lift, I'm guessing your looking at around 2.5" springs, that will equate to 4.5" of lift and going that high will require a lot of other mods like adjustable control arms, SYE, bump stops, steering upgrade is very advisable at that height and a few other things like adjustable track bars and extended brake lines. What you would save by keeping your BB instead of just going to 4" springs is negligible compared to what that 4.5" of lift will cost to do properly.
99_TJ_Wyoming is offline
post #12 of 28 Old 04-27-2013, 05:50 AM
rda616
Now factor a 2" puck on top of a longer then stock lift spring and see how that works! This spring requires more space to avoid coil bind and adding a spacer increases the amount of bump stop extension required not to bind.
Yes, it will work. It simply isn't a good idea.
To the op. Why not just buy a 3.75" kit and be done with it. This kit is a good start if you don't plan on adding a lot of weight later. If you do plan on bumpers, winch, etc, you will want a heavier spring rate.
rda616 is offline
post #13 of 28 Old 04-27-2013, 06:25 AM
Unlimited04
if he just wants to go a little bigger, he should add a 1.25" Body Lift. if he wants to go bigger than that, then it's time for a real 4" suspension lift, with appropriate 4" springs...and all associated components, like an SYE, control arms, track bars...etc
but just because you've been working on TJ's since they came out, doesn't mean you know what you're doing. there's even plenty of horribly setup rigs out there done by "professional" shops.
here's some good reading to catch up:
http://www.jeepforum.com/forum/f9/bu...points-734737/
Useful Write-Ups:
Funny:
post #14 of 28 Old 04-27-2013, 08:29 AM Thread Starter
yoshi280zx
Hey, all!
Thanks for the replies!
Yes, I was kinda looking at "marrying" a 2.5 suspension lift with the BB I currently have. Cost had a lot to do with this. However, it looks like I can possibly get a 4" RC lift with Nitros for under $500. This would essentially put me at the height I would like and stay within my budget. I've heard a lot of horror stories about SkyJackers, but people seem to be pretty satisfied with Zones, RCs and RE lift kits. I'm assuming the full-kits have probably already taken driveline, motor, t-case and pitman / track bar positions into consideration...?
Thanks,
James
James Johnson
1980 280ZX AE -
post #15 of 28 Old 04-27-2013, 06:49 PM
99_TJ_Wyoming
a 4" kit will still be 4" of lift, you would be well advised to concider a 1.25" body lift and 1" motor mount lift to maybe, and I stress maybe forstall the need for the SYE and CV shaft.
budget boost , jeep , suspension lift , tj
