potential REBB install issue - JeepForum.com
post #1 of 12 Old 09-06-2006, 11:28 PM Thread Starter
fish4life
Hello,
Just installing my REBB and something doesn't smell right. When i put the spacer, bumpstop extension, bumpstop and cup in the spacer is loose. Is that right?
Then i put the spring in, thinking the spring will push in and up. I unscrewed the spring compressors and the spring came out but it doesn't seem to be sitting perfectly against the spacer ... yet it looks exactly like this :
(can't tell how well his spring sits against the spacer in this photo)
my question is .... does rotating the spring make any difference what so ever in terms of how it sits against the 2" spacer? I ran out of daylight before i could put the wheel on and lower it ... don't know if that will change the way it sits against the spacer.
many thanks as always.
fish4life is offline
post #2 of 12 Old 09-07-2006, 04:20 AM
Trombino
Trombino's Avatar
1978 CJ7
Originally Posted by fish4life
Hello,
Make sure the spring is lined up with the little indentation on the spring perch. Then lower your jack and see if it is still loose. I am pretty sure it won't be.
'78 CJ7 -- Chevy 350 SBC, Holley 4-BBL, TH700R4, B&M Performance Shifter, Dana 300 w/ Twin Sticks, 3" Shackle Lift, 3" Body Lift, D30 Front (Disc), AMC 20 Rear w/ Moser 1-Piece, 4.10's, 35x12.50/15 General Grabber MT's, Cragar Soft 8's (15x8 w/ 4" BS)
Trombino is offline
post #3 of 12 Old 09-07-2006, 05:44 AM
tcestes
Let me know if this fixes it. I'm installing a BB on mine this weekend and want to avoid possible snags.
tcestes is offline
post #4 of 12 Old 09-07-2006, 07:48 AM
Materdaddy
Materdaddy's Avatar
Snags? This guy's just paranoid! I installed my BB in a little over an hour (mostly) by myself! I did have a little bit of help with somebody to step down on the axle so I could slip the spring in without a spring compressor... worked like a charm!
O|||||||O
Materdaddy is offline
post #5 of 12 Old 09-07-2006, 08:41 AM
Gritz
Gritz's Avatar
The spacer will be loose til you load up the axle. On my install, this happened when I went to the other side and put that spring in.
If you look on the top or bottom of the rear cups that the spring sits in, you should see where is rested before. I just put them back in that area. The fronts have spaces in the bottom cups there they should sit down into.
Gritz
Patriot Blue 2000 Sport
2" REBB, JKS Quicker Disco's
4.0 w/5-Spd
dual tops
"It is believed dinosaurs are extinct due to a giant meteor. That's true if you want to call Chuck Norris a giant meteor."
Gritz is offline
post #6 of 12 Old 09-07-2006, 08:50 AM
idgit0488
Is it normal to not have retainer clips on the springs? Neither my driver or passenger side springs had clips. They are just held in by the weight of the jeep. This was only on the front though. I do not know what it's like in rear as I have not ad a chance to complete the rear.
I'm not an urban cowboy, I'm a country plowboy.
idgit0488 is offline
post #7 of 12 Old 09-07-2006, 08:53 AM
alt13
There is suppose to be retainer clips on the bottom of the front springs, and none on the back.
alt13 is offline
post #8 of 12 Old 09-07-2006, 09:38 AM
tcestes
Why did they design jeeps like this? I would think that the weight of the front with the engine and all would be enough to make sure the springs stay in and would not need the retainers and that the back springs would be the ones that need retainers due to lack of weight resting on them, compared to the front.
tcestes is offline
post #9 of 12 Old 09-07-2006, 10:04 AM
Gritz
Gritz's Avatar
I only had a retainer spring on one of my front springs, I believe it was the drivers side, but could be wrong. The spring actually just slid/rotated out from under the clip, then back in when I was re-installing, so I never had to undo it.
Gritz
4.0 w/5-Spd
dual tops
Gritz is offline
post #10 of 12 Old 09-07-2006, 10:54 AM
tjchad
tjchad's Avatar
My '02 had/has no retaining clips at all. I bought it stock and did the BB myself- there were/are no clips. Been thinking about hitting the dealer for some though. Do I actually need them?
MATER (got it right, eh?)DADDY- I saw your pics on the site- lift looks good!
Chad- KI6BIG
'02 SportD442"BB
Pics:
tjchad is offline
post #11 of 12 Old 09-07-2006, 05:14 PM
Materdaddy
Materdaddy's Avatar
Thanks, and Thanks!!!
To the original poster, mine had retaining clips on BOTH front springs. There was enough grime that I did pull them off, instead of trying to just 'unscrew' the spring from them.
O|||||||O
post #12 of 12 Old 09-08-2006, 02:10 AM
Poor Boy
All Around Nice Guy
Poor Boy's Avatar
i had retaining clips on both of my front springs...well, i still have them.
as to the OP, did through your tires back on and drop your rig down to see if that moved everything back into place?
Originally Posted by Hank Venture
It's like someone with a fever is yelling at my pants!
USN Hull number 54
Poor Boy is offline
Need assistance with potential passenger airbag issue wbgordon TJ Wrangler Technical Forum 7 02-08-2009 07:31 AM
potential issue????? rlj JK Wrangler Technical Forum 41 03-30-2007 07:38 PM
REBB install Questions Thug Nasty TJ Wrangler Technical Forum 18 07-23-2006 08:05 AM
About to install my REBB herxjhistj TJ Wrangler Technical Forum 13 06-10-2005 07:37 PM
REBB Install FlyguyTKI TJ Wrangler Technical Forum 5 05-04-2005 01:23 PM
