Post Zone 4.25" lift question regarding rear shock downtravel - JeepForum.com
 2Likes
  • 1 Post By jski701
  • 1 Post By mrblaine
post #1 of 14 Old 08-20-2017, 12:01 PM Thread Starter
Civeng1741
Yesterday I installed the zone 3" suspension lift and 1.25" body lift combo. Here is a picture of my rear shocks installed sitting on relatively flat ground. As you can see there is only about an inch or two of downtravel before it bottoms out. It doesn't really make sense to me unless im missing something about hydroshocks vs the previous shocks I had. I also included a picture of the front which looks like it has plenty of space to move up and down compared to the rear. Did zone give me the wrong shocks? Is the ford 8.88 making it sit higher? I know the shocks are the right length because I compared it to the shock length +3" budge boost spacers that were on there before and they matched up in height. Any suggestions?
Civeng1741 is offline
post #2 of 14 Old 08-20-2017, 12:39 PM
TheBoogieman
Disturbed Jeepaholic
TheBoogieman's Avatar
My Zone lifts had all the shocks about equal to your front ones.
Originally Posted by jeepinmichguy_ View Post
TheBoogieman is a jerk.
TheBoogieman is offline
post #3 of 14 Old 08-20-2017, 01:20 PM
JEK3
JEK3's Avatar
Can you post a pic showing the lower shock mount?
JEK3 is online now
post #4 of 14 Old 08-20-2017, 01:27 PM Thread Starter
Civeng1741
Here you go
Sent from my XT1635-02 using Tapatalk
post #5 of 14 Old 08-20-2017, 03:07 PM
Mattific
It looks like your rear axle end shock mounts sit up higher by a few inches on your 8.8 than they do on a stock tj axle, likely for clearance. I'm guessing that's your issue. And you don't have a problem with downtravel, the uptravel is limited here
Mattific is online now
post #6 of 14 Old 08-20-2017, 03:16 PM
jski701
Zone 3" rear shock.... looks like you have issues
Sent from my iPhone using Tapatalk
TheBoogieman likes this.
I aint saying its right, but I understand......Chris Rock
My off road trailer build - M416 copy:
jski701 is offline
post #7 of 14 Old 08-20-2017, 03:17 PM
jski701
That's on a d35 rear
jski701 is offline
post #8 of 14 Old 08-20-2017, 03:20 PM Thread Starter
Civeng1741
I see, there dabs 35 mounts do look shorter, how do I find what kind of shocks for nicely for the height I have?
post #9 of 14 Old 08-20-2017, 03:27 PM
Mattific
You'll want to measure and find the length that will best fit it. Pretty much you'll remove the shocks and disconnect the sway bar and flex one side of the axle so the bump stop hits. Then you'll measure between the shock mounting points (where the shock eye would be) for the compressed length. And measure the same thing only for when the axle is drooping to get the extended length
I'm sure there's other threads that explain it better than me
post #10 of 14 Old 08-20-2017, 04:17 PM
mrblaine
Wizard of Brakes
mrblaine's Avatar
You only measure shocks at full stuff and full droop. Articulation will only tell you if you have a problem which would be very rare with most shock locations. The only way you could get articulation to tell the whole story is if the upper and lower shock mounts were in the same front to back and side to side plane as the spring perches.
I am Savvy
blackmagicbrakes.com
mrblaine is online now
post #11 of 14 Old 08-20-2017, 04:20 PM
Mattific
So basically the geometry will give different values at full stuff/droop compared to articulation?
post #12 of 14 Old 08-20-2017, 05:02 PM
mrblaine
Wizard of Brakes
mrblaine's Avatar
When we outboard shocks, we move both mounts. (not that it matters) We leave about 3/4" of shock shaft showing when the Currie Bump stops just touch at full stuff. Under articulation, the shock will bottom out. But, if you think about it, the only time the shock will be doing that is at very low speed with opposite corners stuffed so the dynamic forces that could damage the shock are very low. If you hit the shock under articulation hard enough that you could damage it, you've got a bunch more other things to worry about, like keeping it on all 4 tires.
rbaucom7266 likes this.
I am Savvy
post #13 of 14 Old 08-20-2017, 10:26 PM Thread Starter
Civeng1741
I ended up reinstalling the OEM shocks. Center to top of the shock mounts is about 16". OEM shocks work better than the zone shocks for now since collapsed was 12" vs 15" for the zone. Im now pretty sure that the 8.8 was installed to fit the OEM shocks length with the 3" budget boost.
post #14 of 14 Old 08-21-2017, 08:32 AM
TheBoogieman
Tell Zone the shocks are the wrong length for your setup and they'll send you the correct length ones. I did.
