Post-wheeling, trans problem? help. - JeepForum.com
Go Back JeepForum.com > Models > Jeep Wrangler Forums > TJ Wrangler Technical Forum > Post-wheeling, trans problem? help.
Spartan Locker Promo Running now @ ROCKRIDGE 4WD plus FREERockridge 4WD IS Taking Zone Offroad Suspension Lift Kits Bds fox ipf 2.0 racing series shocks now available at rock
Unread 03-31-2007, 06:07 PM   #1
$lick
Well my first wheeling experience went pretty well today, lots of sandy mud and deep water crossings.
As we are on the way out of the park, I notice that the jeep starts to buck, studder in a way, as if i was letting go of the gas and then punching it while its in the same gear.
As i get on the highway, its more noticeable, each gear.. not everytime, but on occassion.
1st gear through 5th, heavy throttle or light throttle, i get the buck usually in a sequence of 3. feels like throttle, quickly off the throttle, and bam back on it again.
I did get water in the distributor cap, i did have water coming over the hood in some points, but i cleaned the distributor cap and sprayed it.
Only other symptom related to this problem is it has an inconsistent/rough idle, sometimes dipping low as 300 rpms, sometimes normal.
This bucking/spuddering/kicking does not happen
-While not on the accelerator
-While in neutral revving
It happens
-In 4wd, hi and low
-In 2wd
-No matter what speed or how much throttle is given.
And i have no idea on how or what to diagnose this problem as, i am going to flush the tranny, change the diffs.. but i just dont know if this is a tranny problem, a problem with my plugs getting damp or moist maybe and i need to replace them, if its a problem with my rear.
Please help, this is very frustrating as I had to limp home 2 hours today.
1997 Wrangler 2.5L 5spd
Suspension specs:
RE 3.5, 1.25 JKS BL
Old Man Emu shocks
Teraflex adjustable front trac bar
JKS Disco's
Axle specs:
Dana 30- Superior 4.88's
Detriot tru-trac locker
Dana 35- Superior 4.88's
Riding on:
33x12.50 BFG A/T
Black Cragar soft 8's
$lick is offline   Reply With Quote
Unread 03-31-2007, 06:10 PM   #2
Red_
Did you get some mud or something on the clutch?
Red_ is offline   Reply With Quote
Unread 03-31-2007, 06:31 PM   #3
$lick
highly unlikely, i only depressed the clutch once on accident when i got into a sticky situation, could be the problem.. but how would that be.. it shifts fine, the clutch still grabs exactly the same, and the gear shifting is smooth.
im thinking the distributor cap/wires/plugs got wet and are crapping out.
Suspension specs:
RE 3.5, 1.25 JKS BL
Old Man Emu shocks
JKS Disco's
Axle specs:
Riding on:
33x12.50 BFG A/T
Unread 03-31-2007, 07:22 PM   #4
$lick
Suspension specs:
RE 3.5, 1.25 JKS BL
Old Man Emu shocks
JKS Disco's
Axle specs:
Riding on:
33x12.50 BFG A/T
Unread 03-31-2007, 09:48 PM   #5
bigV
did you get any odb2 codes? I had similar symptoms after a day of mudding, but I got an error code right away. P301 - cylinder 1 misfire, it turned-out to be a bad o2 sensor - I replaced all of them and after my last water/mud outing I had no problems
bigV is offline   Reply With Quote
Unread 03-31-2007, 10:26 PM   #6
safarimike
x2 on the o2 sensor. I stalled out in a deep crossing before and it ran rough, a surged a about 300 rpms some times. I got a check engine light that indicated o2 sensor.
1999 Jeep Wrangler Sport
safarimike is offline   Reply With Quote
Unread 03-31-2007, 11:47 PM   #7
Jackle
it sounds more like the TPS (throttle positino sensor) has either gone bad or has gotten we and caused it to go bad.......when they freak out they don't really know what to tell the engine to do....usually resulting in something that looks like a noob trying to learn to drive a stick
Jackle is offline   Reply With Quote
Unread 04-01-2007, 12:07 AM   #8
Chris_
i had a truck that did the exact same thing. were were playing in a creek in deep mud. i got out of the creek, and had that same problem. real hard bucking. it eventually died. it turned out that the rotor under the distributor cap was broken off just enough to screw it up.
'02 TJ X Apex Edition
'00 XJ Sport
Chris_ is offline   Reply With Quote
Unread 04-01-2007, 08:51 AM   #9
$lick
It did throw a code. the code is 24 apparently.
I went on, off, on off, on off (not fully on) like your supposed to.
it went through the series of 111111 etc 22222 etc and then said 24 and my check engine (that came on while wheeling yesterday) was blinking while 24 was on. ill go try the codes again, you hold the odo and go on off on off on off(not fully on) corect?. any idear what 24 that means? im going to try to google it..
Suspension specs:
RE 3.5, 1.25 JKS BL
Old Man Emu shocks
JKS Disco's
Axle specs:
Riding on:
33x12.50 BFG A/T
Unread 04-01-2007, 09:34 AM   #10
$lick
edit.
found the right way to do it.
got codes 12, 24, and 55. but 55 doesnt matter correct it always does this?
Suspension specs:
RE 3.5, 1.25 JKS BL
Old Man Emu shocks
JKS Disco's
Axle specs:
Riding on:
33x12.50 BFG A/T
Unread 04-01-2007, 12:51 PM   #11
JeepMKcomin
in case you didnt already look:
http://www.jeepforum.com/forum/showt...threadid=23788
...and to answer your question, I dont think 55 should matter.
06TJ Silver Ruby - REBB w/DT3000s, Quick Discos, Superwinch EPi9.0, Warn engine skid, PS Box Skid, Diff Guards, IPF Lenses, x51s soon
92YJ White - Slight Shackle Lift w/30x9.5 BFG ATs, Custom Beefy Bumpers
06TJ Khaki Sport - Traded in
JeepMKcomin is offline   Reply With Quote
Unread 04-01-2007, 01:05 PM   #12
ImSuck
hmm maybe tps sensor? not sure
-Andrew
Low Output 4 Cylinder Jeep Club member #59
[QUOTE=Grewe02]No such thing. Eat **** and die.[/QUOTE]
lifted with some extra's
......sold
ImSuck is offline   Reply With Quote
