Post OME 2.5 / 33x12.0 ?s, tire pressure, brakes, klangs - JeepForum.com
post #1 of 2 Old 07-07-2010, 09:13 AM Thread Starter
Faramir66103
Hi Folks,
We recently got our OME 2.5" lift on and finally got some 33"x12.5"r15 BFG A/Ts on our '99 TJ. We're both enjoying it though we've not had the opportunity to take it off pavement yet. Hopefully I'll remedy that in the next week or so. Running it around town I've noticed some things and have some questions.
The tire shop aired us up to 38 PSI, and the ride was a bit harsh compared to my 5 year old 30" BFG A/Ts at 30PSI. Yesterday I dropped it down to 30, and it seems a little better, but that could be wishful thinking on my part. What pressure would you all recommend for these tires? I've heard of a chalk test, but don't know how to do it or how to read the results. Could someone elaborate?
I've noticed the loss of power everyone talks about, and it's more than I was expecting. Can I get to 4.56 with just a ring and pinion swap for the 30/35 combination, or is there more involved? I can probably learn to live with it for the time being and hopefully within the next year either regear or do an entire axle swap.
What I wasn't expecting was how much more braking pressure I need to apply. There's a good chance my pads and rotors are close to replacement time anyway, so I am considering the EBC/Centric upgrade. Could someone point me to the proper part numbers and/or good place to purchase them?
Lastly, if I let the engine lug when starting from a stand still, I'll hear a clang from what seems to be the rear, and now from directly under me. I've looked at and pulled/pushed on everything I can think of under the Jeep, and spent time looking for scraped paint, rust etc. that might indicate a loose or vibrating part and can't find anything. It also seems to lug more easily, so I checked the clutch fluid and it is right up where it ought to be and I'm not feeling any degraded clutch performance. Any thoughts?
Thanks,
Adam
'99 TJ Sport, 4.0 I6, 5 speed manual transmission, Hi Lift w/offroad kit, Viair 450C compressor, Garmin GPS, Skid Row Engine/Transmission, steering box & radiator skid plates, Kilby gas tank plate, AtoZ Fab full length rocker guards, Performance Accessories 1" Body Lift, OME 2.5" HD springs & shocks, JKS trackbars front & rear, BFG AT 33x12.5r15, EBC Yellow pads and Centric rotors
Faramir66103 is offline
post #2 of 2 Old 07-07-2010, 09:50 AM
Unlimited04
This post/info=my opinion
Unlimited04's Avatar
tire pressure for those should be around 26-29psi area. got any chalk? do a chalk test and find out....you're looking for an even wear pattern.
regearing isn't a difficult job, you just need the right tools and knowledge to use them. leave regearing to the professionals who do it everyday.
braking is significant. i'm running the EBC/Centric's right now, i've run them on 31s and now 33s. they still leave quite a bit to be desired. Vanco brakes would be the way to go.
powerbrakes hydroboosts vacuum boosters everything for your extreme braking needs
Useful Write-Ups:
Fabrication & Build:
Funny:
Unlimited04 is offline
tire , psi , gear , swap , brakes , TJ
Pressure to run 33x12.5r15 Duratracs for DD use? troyinne TJ Wrangler Technical Forum 31 06-25-2010 05:34 AM
Tire pressure question - 33x12.50x15 dumped TJ Wrangler Technical Forum 7 03-30-2009 03:15 PM
Will a 33x12.5x18 tire (OEM rim) fit on the stock spare tire carrier? squid2004 JK Wrangler Technical Forum 7 10-07-2007 01:56 AM
33x12.5s Tire Pressure and Speed. jeepdude101 TJ Wrangler Technical Forum 9 07-14-2005 03:06 AM
Tire pressure foe 33x12.5x15 tires JAXTOY 2 TJ Wrangler Technical Forum 4 05-06-2004 12:05 AM
