Post lift questions - JeepForum.com
post #1 of 13 Old 03-25-2013, 09:21 PM Thread Starter
DirtRider1357
Post lift questions
Can someone with a rubicon, stock or lifted take a picture of their passenger side coil spring and knuckle. The clearance between the two on mine is very small compared to the driver side.
87 YJ, 4.0L, 5speed......sold, 05 LJ Rubicon
"It'll buff out"
"If it moves and shouldn't, use Duct Tape & Zip Ties. If it doesn't move and should, use WD-40 & A hammer"
DirtRider1357 is offline
post #2 of 13 Old 03-25-2013, 09:37 PM
CommonSense
Sorry no rubicon here. well... no (suspension) lift here either... I did however, notice that when I purchased my TJ, the passenger side settled lower than the driver side. The overall difference was noticeable. Did you notice (or even measure) the four wheelwell-to-tire distance differences BEFORE the suspension lift was installed? They very well may have been there before the suspension lift...
CommonSense is offline
post #3 of 13 Old 03-26-2013, 06:25 AM
VBRubicon
VBRubicon's Avatar
You need an adjustable track bar. What/how much lift did you go with?
"Yeah well, that's just like...your opinion, man."
-El Duderino-
Mr. Madison, what you've just said ... is one of the most insanely idiotic things I have ever heard. At no point in your rambling, incoherent response were you even close to anything that could be considered a rational thought. Everyone in this room is now dumber for having listened to it. I award you no points, and may God have mercy on your soul.
VBRubicon is online now
post #4 of 13 Old 03-26-2013, 10:29 AM Thread Starter
DirtRider1357
zone 4 inch. the kit required redrilling the the track bar bracket on the axle side.
"It'll buff out"
post #5 of 13 Old 03-26-2013, 11:04 AM
JBTJ
That's what I had to do.
JBTJ is offline
post #6 of 13 Old 03-26-2013, 11:25 AM Thread Starter
DirtRider1357
i did redrill the bracket. the coil spring is sitting closer to the knuckel on the passenger side then it is on the driverside. also the sway bar links are sitting different on each side.
"It'll buff out"
post #7 of 13 Old 03-26-2013, 11:27 AM
JBTJ
Got pics? looking at the front of the jeep which direction did you drill the new hole?
JBTJ is offline
post #8 of 13 Old 03-26-2013, 11:29 AM Thread Starter
DirtRider1357
ill take pictures after class today
"It'll buff out"
post #9 of 13 Old 03-26-2013, 11:30 AM Thread Starter
DirtRider1357
i drilled the hole 3/4" towards the driverside
"It'll buff out"
post #10 of 13 Old 03-26-2013, 11:34 AM
JBTJ
Hmm, that's what I did too. Guess you're going to have to get an adjustable track bar.
JBTJ is offline
post #11 of 13 Old 03-26-2013, 11:59 AM Thread Starter
DirtRider1357
would being out of alignment cause this type of problem. i havent had it aligned since the lift went on yet.
"It'll buff out"
post #12 of 13 Old 03-26-2013, 12:02 PM
JBTJ
No, but it needs to be done anyway.
JBTJ is offline
post #13 of 13 Old 03-26-2013, 02:10 PM
NotURMailman
NotURMailman's Avatar
You need to get the axle centered before the alignment.
equipped... And loving it!
I drive on the right side, what's wrong with you?
It's difficult to take you seriously. It's like you're an easily perturbed autistic teenager who's drunk typing the whole time.
NotURMailman is offline
