Is it possible to install a mml and Tummy tuck without a body lift - JeepForum.com
post #1 of 7 Old 08-30-2009, 06:49 PM Thread Starter
blackruby56
I saw a post where someone said they made modifications so they could install their skyjacker tummy tuck without a body lift and was wondering if i could possibly get rid of my 1" body lift. I doubt it but just wanted to check.
blackruby56 is offline
post #2 of 7 Old 08-30-2009, 06:59 PM
Imped
Imped's Avatar
You can but you'll have to make space by pounding out some room in the tub and/or shave a bit off of the transmission mount.
OlllllllO
IndyORV
Imped is offline
post #3 of 7 Old 08-30-2009, 07:01 PM
emev0l
The AEV tummy tuck for 02 and under TJ's will work without a body lift and no tub modifications.
Since you have an 03 and up I'm pretty sure it requires you to dimple your tub.
2001 TJ 4.6 Auto 4.5" AEV suspension 35's
2002 TJ 4.0 Manual 3" BDS suspension 33's
1987 Chevy 1 Ton 12" suspension 44's
1970 Cutlass 442 468CID TH400
1999 7.3 Powerstroke
emev0l is offline
post #4 of 7 Old 08-30-2009, 08:33 PM
Deacon
Shining Adonis
Deacon's Avatar
Why would you want to do all that instead of installing a simple and effective 1" or 1.25" BL?
Deacon is offline
post #5 of 7 Old 08-30-2009, 09:06 PM
Unlimited04
This post/info=my opinion
Unlimited04's Avatar
crawl under your Jeep. try to put your hand all the way around the t-case, trans, bellhousing and all the way up to the engine. If you can find 3" of clearance, you'll fit everything fine. but you won't find this clearance - you're lifting the entire drivetrain 2.5" of more. All this drivetrain has to go someplace...you install a BL to make room. Or you can remodel the firewall and tunnel of your tub with a hammer for a few hours. or use a hydraulic ram to seperate the tunnel & firewall a bit. or wait until various components rub on your firewall and tub, becoming damaged.
a BL does give you advantages - you can run a high clearance gas tank skid (like Savvy or Rokmen), you need 1" less bumpstop for the same size tires, and you get extra room making maintenance easier.
Useful Write-Ups:
Fabrication & Build:
Funny:
Unlimited04 is offline
post #6 of 7 Old 08-30-2009, 09:41 PM
RogueSpear2023
Do the body lift you can't even tell its there. My jeep is stock for now with a 1.25" BL and 1" mml and you don't even notice it it, niether does anyone else unless you mention it.
Max
2003 Jeep Wrangler Rubicon
4.0L, 42RLE, Dual Tops, Full Doors, JKS Front Disconnects, Cragar Soft 8 Black Wheels, 33x12.5x15 Goodyear Duratracs, .75" Front Coil Spacers, Bushwacker 6" Flat Fender Flares, Skid Row Steering Box Skid, LubeLockers, Rubicon Locker Mod, OBA, Cobra 19 Ultra III CB, 3' Firestik, Rough Country 2.2 Steering Stabilizer, RC 1.25" BL, RC 1" MML, RC Grab Handles, Fog Lamp Bent Pin Mod, 4" Apline S Series Speakers, Kenwood Excelon 6.5" Speakers, 6.5" JL Audio 6W3V3 Subwoofer (in center console) w/MTX Thunder 202 amp, IPF H4 Headlight Housing, Sliverstar H4 bulbs.
"Buying a jeep and not taking it off road, is like buying a dragster and never taking it to the track"
RogueSpear2023 is offline
post #7 of 7 Old 08-31-2009, 02:55 AM
Yesfan70
Yesfan70's Avatar
Since you already have the body lift, I would just leave it and do the TT. From what I have read here, every who has done one says it is SO much easier with a 1-1.25" BL.
2004 Jeep WJ
Only in a Jeep
Yesfan70 is offline
Suspension lift vs. body/engine/tummy tuck dcope17 TJ Wrangler Technical Forum 8 12-29-2009 03:19 PM
Belly up/Tummy tuck. No body lift? REDLYNER TJ Wrangler Technical Forum 13 10-28-2009 12:21 PM
Tummy Tuck and Body Lift Gymguyjeep TJ Wrangler Technical Forum 17 05-01-2009 03:49 PM
Tummy Tuck, MML, NO body lift??? brunosplace TJ Wrangler Technical Forum 1 02-28-2009 12:08 PM
Tummy Tuck/Flat Skid, No Body Lift? brunosplace TJ Wrangler Technical Forum 22 10-31-2007 11:56 AM
