Is it possible to flush mount... - JeepForum.com
post #1 of 8 Old 07-20-2004, 08:09 AM Thread Starter
BunnyHunter
BunnyHunter's Avatar
Normal, square Jeep taillights? I love the standard look but hate the jutt-out. I want them flush. If anything, I want those new ones in quadratec.
Is there a way to flush mount lights like those...like stock?!?!?!
Thanks!
Kim
Real Chicks go TOPLESS!
It's my daily drive. If I roll it, I'm *&^%$#ed.
BunnyHunter is offline
post #2 of 8 Old 07-20-2004, 08:34 AM
wayoflife
as a matter of fact, yes. i have seen plenty of guys do this. unfortunatly, i don't know of any write-ups out there on how best to do this.
wayoflife is offline
post #3 of 8 Old 07-20-2004, 09:56 AM
04TJFan
Take off the light and make a template of the back of the light up to the flat ridge that the lens mounts to. You may have to do a little trimming to make the template fit just right. You want to be able to slide the whole light assembly thru the hole and have it rest on the flat ridge. Now you may have to take off all the reflectors and license lightl lenses and such on the sides so you just have a smooth outer shell. You'll probably have to make some covers for the holes that fit inside the light bucket if you don't have the abililty to weld the holes shut. Make sure theres nothing behind where you want to put the light and cut the hole to the size of your new template. Finish the edges to prevent rust. Cut a thin gasket out of stock material to seal the flange to the body and slide the light bucket into the hole you made. You will have to drill a few holes in the lip of the light to secure it to the body, then put the lens back on and your done.
It's easy to write up how to do it but it you pay attention to details and take your time you should be able to do this yourself.
Good Luck and post some pictures when your done.
Scott
Black Jeep Club Member #2004
Jarhead Jeep Club Member #4
Rubicon Express 2" Budget Boost
Performance Accessories 1" Body Lift
Daystar 1" Motor Mount Lift
Bushwacker Fender Flares
04TJFan is offline
post #4 of 8 Old 07-20-2004, 01:15 PM
UTAH
UTAH's Avatar
I haven't checked, but NJ might have statute defining the requirement of lighted rear plates.
(Note: my Jeep is not legal in a few areas either, but with our lax enforcement - it's not an issue here)
Bill
'97 Land Rover D90
'03 TJ Rubicon
'14 JK-8 Freedom Edition
'14 KL Cherokee Trailhawk
UTAH is offline
post #5 of 8 Old 07-20-2004, 01:57 PM
KaiserJeep
The stock rear light assemblies also provide side reflector and red running light functions, and license plate illumination on the left side. If you sink the lights flush you will be missing such required equipment, or have to replace these functions with seperate lights and reflectors.
In fact you are unlikely to get pulled over for such equipment infractions. However if a cop pulls you over for a moving violation, that's an easy additional thing he will add to the ticket if he doesn't like your attitude. The other item is if you are ever hit in a rear collision, whoever hit you can say the real cause was your illegal modification and missing required safety equipment.
It's not worth it IMHO just for the look.
Gary
1967 Kaiser Commando
2001 Grand Cherokee WJ
2003 Wrangler Rubicon TJ
KaiserJeep is offline
post #6 of 8 Old 07-20-2004, 02:09 PM
04TJFan
The description I gave is the basic process for doing the modification that was asked about. The attention to details line is meant to cover the additional modifications that will arise from doing the modification. It is the owners resposibilty to make sure that there motor vehicle meets the code of what ever state or country they live in. Sometimes the customizing process is easier than the modifications to make it legal. Just my .02
Scott
04TJFan is offline
post #7 of 8 Old 07-20-2004, 02:13 PM Thread Starter
BunnyHunter
Ummm...yeah.
Not worth it. Think I'll just buy the upgraded "fashion" lights and go with those.
Loveofmylife just baught new taillights for the 61 Willy's and the rounds would look awesome...but again...don't want separate back-up lights and I like the convenience of the clip for the wiring. I'm not into rewiring the whole rig to fit a pretty light!
Thanks for all the input!
Kim
post #8 of 8 Old 07-20-2004, 02:20 PM
his15153
I'm not sure about the side reflectors, but as for the license plate light, that is an easy fix. Theirs a kit available that has LED lights built into the nuts that hold the license plate. That will allow the license plate to still have the necessary lighting.
his15153 is offline
flush mount taillights johnroot01 YJ Wrangler Technical Forum 0 09-14-2009 06:50 AM
Flush mount LED's ReyesYJ YJ Wrangler Technical Forum 18 01-13-2009 11:12 AM
Flush mount taillights jdietz92 YJ Wrangler Technical Forum 6 09-24-2008 04:31 PM
flush mount lights ponytail YJ Wrangler Technical Forum 13 12-02-2007 07:16 PM
Flush Mount Taillights RLD831 TJ Wrangler Technical Forum 28 03-10-2007 01:14 PM
