possible drive line vibes - JeepForum.com
post #1 of 10 Old 06-02-2011, 05:00 PM Thread Starter
jeepguyvt
hi i have an 06 wrangler X with a series 2 lift from rough country. i added rear upper adjustable control arms, adjustable rear track bar, and a Perf. Steering Stabilizer. nothing has helped the vibrations. the adjustable control arms helped the angles from the lift but it didnt help the vibrations, short of replacing the drive shaft and getting a YSE i dont know what else to do...i dont have the cash to do the DS/YSE atm.
i can post pictures of anything just ask and i will take them.
suggestions pls! if im leaving any info out/if you need more info i will do my best to give the correct info.
jeepguyvt is offline
post #2 of 10 Old 06-02-2011, 05:08 PM
TheBoogieman
Disturbed
TheBoogieman's Avatar
A series II 4" lift? A MML or small t case drop with washers would fix it.
TheBoogieman is offline
post #3 of 10 Old 06-02-2011, 05:49 PM Thread Starter
jeepguyvt
it has a drop case..im thinking i might have to much of an angle...im gonna take it some where level and try to get a better measurement. my drive way is all kinds of messed up. it says its about 14.6 degrees and should be around 9 im hearing. ill get a accurate measurement tomorrow. but im guessing thats my issue. i was frustrated couldnt think till a friend came and helped...i see clearly now!
post #4 of 10 Old 06-02-2011, 06:51 PM
TheBoogieman
Disturbed
If it's the 4" lift,the t case drop isn't enough.I've installed many RC 4" lifts and a MML would let you get rid of most of the t case drop.Both Jeeps have RC 4" lift with a MML and 5/8" t case drop and NO vibes.
post #5 of 10 Old 06-03-2011, 10:24 AM Thread Starter
jeepguyvt
i took it to a shop this morning and they said the angle is good now...but the U joints need to be replaced because of the angle they were at. cheap and easy fix hopefully it will fix it
post #6 of 10 Old 06-03-2011, 10:29 AM
bnine
Ya, just changing the operating angle on shafts can cause vibs sometimes because it throws them out of phase. Essentially the joints get used to operating where they are at, and wear accordingly. If you change that angle, it can really bring to light how worn the joints actually are.
Common issue after lifting.
bnine is offline
post #7 of 10 Old 06-05-2011, 05:57 PM Thread Starter
jeepguyvt
the shaking is fixed for the most part after the U joint replacement. Now my only issue is the steering wheel since i put in a new steering stabilizer it kinda feels like the wheel is pulling the right when i hit a bump, the alignment is good. and i seem to have alot of play in the steering wheel. it didn't do this post lift...only post steering stabilizer, i checked it, it doesn't seem to be damaged or loose. it also feels different turns left then it does right....but that might all be in my head =/
Perf. Steering Stabilizer from roughtcountry.com
post #8 of 10 Old 06-05-2011, 06:09 PM
OCS12
You might as well be describing my Jeep. Wicked vibrations under acceleration turned out to be a bad U-joint on the rear driveshaft. Wonky steering was caused by the drop pitman arm that was part of the lift kit. Swapped it out for a stock pitman arm and life is good.
OCS12 is offline
post #9 of 10 Old 06-05-2011, 06:27 PM Thread Starter
jeepguyvt
ya my pitman arm is stock =/ series 2 kit from RC
post #10 of 10 Old 06-07-2011, 04:25 PM Thread Starter
jeepguyvt
Ya it definitely seems like the steering stabilizer is bad....its new though guess ill give RC a call
drive line vibes. 02OlllllllOTJ TJ Wrangler Technical Forum 2 04-10-2010 01:08 PM
Drive line vibes gone txflood3 TJ Wrangler Technical Forum 2 08-31-2008 08:04 PM
Drive line vibes Twister_EMS TJ Wrangler Technical Forum 3 03-22-2008 01:24 PM
Drive Line Vibes Toolshed TJ Wrangler Technical Forum 4 01-06-2008 08:10 PM
