popping sound in engine - JeepForum.com
Go Back JeepForum.com > Models > Jeep Wrangler Forums > TJ Wrangler Technical Forum > popping sound in engine
Introducing MONSTALINER™ UV Permanent DIY Roll On Bed LineSpartan Locker Promo Running now @ ROCKRIDGE 4WD plus FREELifetime LED on Sale at Baseline 4x4 Outfitters LED Light
Unread 11-26-2003, 11:15 AM   #1
gdixon
I have a 99 4.0 that is making a popping sound in the engine whenever it has a load on it (i.e., accelerating, too high gear, etc.). It sounds like an exhaust leak, but I can find no leaks and I have the full Banks exhaust system. the sound seems to be coming from the top of the engine near the rear of the block. The sound is annoying, but it has not produced any noticeable effects on engine performance. Any suggestions as to what this might be?
thanks
gdixon is offline   Reply With Quote
Unread 11-26-2003, 08:52 PM   #2
Bachman
It kind of sounds like it may be preignition detonation. Try running a high octane gas. That might solve the problem..
2000 TJ, 4.5 Custom Long Arms, Detroits front and rear, 4.56's, 4 to 1, 35 BFG muds for now, Flowmaster, TBT Roll Cage, Flat Skid.
Bachman is offline   Reply With Quote
Unread 11-26-2003, 08:58 PM   #3
xxxflhrci
It shouldn't need premium fuel to prevent pinging. I don't think your engine call for premium. Check your owner's manual.
Your pinging is probably a timing issue. Retarding your timing a few degrees should solve the problem.
Premium gas in an engine that doesn't need it is a waste of money. You won't get better mileage, more power or make your engine last longer.
xxxflhrci is offline   Reply With Quote
Unread 11-26-2003, 09:09 PM   #4
thephantum
1997 XJ Cherokee
Ya, you should not need premuim fuel. The 4.0 is designed to run on 87 or 89 octane. Using higher octane might mask the symptoms, but the problem will still exist.
You might have a bad sensor (O2, TPS, etc) somewhere sending erronous signals and causing the computer to set the wrong timing curve.
How many miles have you got on it? You might also just have some carbon buildup causing the detonation.
Good Luck!
Rock On!
Steve
[CENTER][SIZE=3][URL=http://www.fm2cd.com][COLOR=darkred]Follow Me To Certain Death 4x4 Club VA Chapter Founder[/COLOR]
[/URL][/SIZE]
[size=3][url=http://jeephorizons.com][COLOR=sienna][b]Jeep Horizons - Where Avatars are always free[/COLOR][/b][/url][/size]
[B][size=3][url=http://www.links4jeeps.com/in.php?id=893/]Links 4 Jeeps - Yup, they're free here too[/url][/size][/B]
[URL=http://www.fm2cd.com/chapters/VA_Chapter/VA_Members.htm#cname]
97 XJ Sport 2 door with a bunch of stuff[/URL]
[url=http://www.fm2cd.com/chapters/VA%20Chapter/VA%20Members.htm#dname]
02 TJ Sport with a bunch of stuff[/url][/center]
thephantum is offline   Reply With Quote
Unread 11-27-2003, 06:05 PM   #5
doorocks
thanks
From my past experience, it could very well be the seal on a fuel injector. Injectors pulse when sending fuel, they don't spray continuously. It's fairly high PSI, in a confined area with no way to escape but through the easiest route......a bad ring. Very easy to check and fix. But if you've never removed a fuel rail before, have someone help you that has or buy a FSM for the step by step. The injectors HAVE to be pulled straight out and seated in the same fashion or it will not seat correctly in the rail itself, causing a nasty fuel leak. The ring kit is about 12.00.
Ask me how I know.
Let us know what the solution finally is for our data banks.
[B][COLOR=Black]LIFE IS TOUGH ENOUGH ALREADY, IT'S EVEN TOUGHER WHEN YOU'RE STUPID.[/COLOR][/B]
RE 3.5 and all kinds of other relevant goodies, you know winch and stuff.
[COLOR=Red][B]Life is like walking into the No Chance Bar full of Future Darwin Stories........[/B][/COLOR]
More mods than a hillbilly's set of teeth..
doorocks is offline   Reply With Quote
