post #1 of Old 07-10-2007, 02:45 PM Thread Starter
lennyg
Popping noise when start moving..
00 wrangler,4.0 manual,150K miles
When starting to move there is a popping noise coming from somewhere under the jeep. I thought maybe it was the u-joints going out but If I coast and turn sharp corners it doesn't do it. When you first start moving forward it pops. Almost the same kind of sound you get when a tranny pops out of gear but its not.When turning corners it gets worse and it pops even more until you get going straight. While driving normal it does not pop. Only when you first get the jeep moving.
I climbed under the jeep and grabbed the front drive shaft and tried turning it. It doesn't move much but there is kind of a clank sound coming from the right side somewhere. Any ideas on this?? Could it be low on lube? I thought about removing the front drive shaft to see if that would do anything.
This is my ex wifes jeep and the only way she has to drive back and forth to work so I need to try and get this fixed asap.
lennyg is offline
post #2 of Old 07-10-2007, 03:13 PM Thread Starter
lennyg
Update..
Removed front drive shaft..Popping noise still there. It sounds like someone is hitting something with a mallet. Only seems to do it when you first start moving and when turning some corners.small turns seem to be ok,but when turning onto another street it pops sometimes several times untill the jeep straightens out.
Checked Fluid level.-its right at the bottom of the hole where it should be.
I cant see/feel anything else loose on the front. IM going o takeit to aparking lot and make sure it is Straight as can be and start off and see if it pops. I know it pops when turning corners.
lennyg is offline
post #3 of Old 07-10-2007, 03:26 PM
red2001tj
Check the torque on your control arm and track bar bolts. I had a consistent pop every time I started and it turned out one of my upper control arm bolts was a little loose.
red2001tj is offline
post #4 of Old 07-10-2007, 03:34 PM
97_tj
mine would squeek and pop come replaced my worn out lower arm bushing and has been quite as a kitten ever since
97_tj is offline
post #5 of Old 07-10-2007, 03:34 PM
Jeepguy1977
Jeepguy1977's Avatar
this Jeep doesn't by chance have a factory trac-loc in it does it?
1998 TJ, 4.0L Auto and various junk
Rolled Red Jeep Club Member #7
Jeepguy1977 is offline
post #6 of Old 07-10-2007, 03:55 PM Thread Starter
lennyg
I saw in another post something about the transfer case chain slipping.
I took it to a parking lot and started off moving straight and it is still popping. It sometimes sounds like three or four people are hitting something on the botom with a mallet,other times its just one pop or two. I had the jeep moving about 20 and turned some really sharp turns and there was no popping. Its only under accleration that it is popping.. This jeep has been off road very little, it is driven about 98% highways back and forth to work. I dont see how the chain could stretch out when 4x4 is very rarely used at all.
Is there any way to verify or rule out the transfer case chain?
lennyg is offline
post #7 of Old 07-10-2007, 04:00 PM Thread Starter
lennyg
Not sure. How do I check that?
lennyg is offline
post #8 of Old 07-10-2007, 04:02 PM
red2001tj
Removing the front drive shaft rules out the tc chain most likely since the chain will only move in 2WD if the front driveshaft is connected.
post #9 of Old 07-10-2007, 04:05 PM
fish4life
I had this same issue, and i was convinced my tranny was jumping around .... due to vibes.
I was all set to do a Motor Mount lift, but in the meantime i changed my shocks from cheap RE twin tubes to Old Man Emus, once changed i took it for a test drive and the popping, clunking was gone completely .... guess it was a bad shock because I've been clunk free for a week now....
not sure if it's the same as your problem, just a possiblity, since i had the same type of sound right at take off as well.
Not saying go out and buy new shocks, just give them a good inspection for leaks, loose bolts etc etc.
fish4life is offline
post #10 of Old 07-10-2007, 04:06 PM Thread Starter
lennyg
I removed the front drive shaft from the axle but left it connected to the TC. pulled it about 5 feet forward and it started popping. I was watching the drive shaft to make sure it wasn't turning at all.
If not the chain...any other ideas???
lennyg is offline
post #11 of Old 07-10-2007, 04:07 PM Thread Starter
lennyg
IM pretty sure its not a shock. It only does it when under accel. When stopping,it does not do it and if im driving and give it some gas it sometimes does it also.
lennyg is offline
post #12 of Old 07-10-2007, 04:15 PM
Jeepguy1977
The easiest way to tell if you got a trac-lok is to get ahold of your build sheet. If it's not working, I don't know a good way to tell. Maybe someone else on here does. I don't remember the link for getting the build sheet, but I'm sure it's on the forum here in enough places. Does it do it around corners? If so, it really sounds like clutch packs in the trac-lok to me.
post #13 of Old 07-10-2007, 04:30 PM
fish4life
Mine only did it on take off, never while driving ... but i'm sure glad it's gone.
post #14 of Old 07-10-2007, 04:33 PM
NJStriper
2003 WJ
The problem I'm trying to describe in the other thread sounds like the same thing. I'm pretty sure I have the factory trac-lok. What could be the problem with that?
NJStriper is offline
post #15 of Old 07-10-2007, 04:36 PM
jeepnmike
jeepnmike's Avatar
How about the TC shifter linkage? Mine does the same thing, especially on bumps. There is a TSB for it which I havent done yet. Check yours out. The bushings/collars/etc suppsedly wear out and make a lot of noise
'95 YJ- 1.25" BL, 31" bfg's, black cragars, herc'd tub. sold
'99 TJ Sport- 35's, 8.8, 4.88s, 5" RC LA, JB SS SYE, UFC TT, HD steering
jeepnmike is offline
A toc sound when i start moving in the back mmarmouz TJ Wrangler Technical Forum 0 10-09-2009 11:42 PM
Popping noise in front end when i start out Ghanja TJ Wrangler Technical Forum 3 03-04-2009 10:09 AM
noise when jeep is moving vargeg60 TJ Wrangler Technical Forum 2 09-30-2006 07:22 PM
Clunk when I start moving?? Dave Mathews TJ Wrangler Technical Forum 2 06-23-2004 09:36 PM
You may not post new threads
You may not post replies
