Popping noise from rear end... - JeepForum.com
post #1 of 4 Old 10-30-2010, 09:39 PM Thread Starter
Mchristian1
Hello everyone.
I was hoping I might get some advice on a problem I have with my 2005.
When I decelerate, I get a popping noise from the rear end...it is very noticeable and slows as the vehicle slows.
Do any of you know what the cause of this could be?
I just had the oil changed in the front and rear differentials. This is the only work done recently. The vehicle has a 3" teraflex lift.
Any help would be appreciated. Thank you very much.
Mchristian1 is offline
post #2 of 4 Old 10-30-2010, 10:52 PM
wushaw
Rockin jeep
wushaw's Avatar
Check the pinion nut for security.
wushaw is offline
post #3 of 4 Old 10-31-2010, 02:59 AM
Knuckelhead
AFSOC Retired
Knuckelhead's Avatar
Fill in your profile...
Knuckelhead is offline
post #4 of 4 Old 10-31-2010, 07:01 AM
williambmac
Could possibly be the clutches if you have a limited slip in the rear. You said the fluid was changed recently, did you have the condition prior to the fluid change?
Limited slips require slip additive.
Have you checked the splines inthe rear driveshaft? is there any play in them? When was the last time the splined were greased?
If all the above check out, there could be a strong possiblity the spider gears are worn, especially if it is a d35 in the rear.
2000 TJ 5.5 Long arm, lots of extras. R.I.P.
2005 LJ rubi 35's Clayton, lots of extras
williambmac is offline
Popping noise in the rear end of a JK zryoung01 JK Wrangler Technical Forum 1 05-11-2009 11:41 PM
Popping noise from the rear 05RedRME TJ Wrangler Technical Forum 9 02-17-2009 07:48 PM
popping noise from rear suspision stevenr TJ Wrangler Technical Forum 8 05-28-2008 11:57 AM
Rear popping noise dogbluedrummer TJ Wrangler Technical Forum 2 03-09-2007 06:44 PM
popping noise in rear end chadwickinator TJ Wrangler Technical Forum 1 03-28-2006 12:32 PM
