popped out of alignment? - JeepForum.com
post #1 of 10 Old 12-04-2005, 11:51 AM Thread Starter
splitskater
splitskater's Avatar
i just got out of the woods, when i went in my steering wheel was straight, when going through a mud puddle i started to get bogged down gave it some gas and hit a rock or something solid in the puddle pretty hard, well when i got back out on the road i noticed that in order to steer straight that the steering wheel had to be turned halfway to the left to go straight, it doesnt pull either way but has to be halfway turned to go straight, upon inspection nothing seems broken, no noises when turning the wheel, when parked i straightned the wheel and the tires were turned to the left a decent amount.
is it just out of alignment or could it be another issue that i am not seeing?
FOR SALE on ebay for a TJ WRANGLER
OME 2 1/2" HD Lift Kit
Warn Front bumper
Stinger guard
Currie HD Steering kit
BDS Adjustable track bar
Auctions End 10/29/06 Ebay username is: splitskater
check it out, PM me for any questions
5-31" Kumho MTs on cragars FOR SALE in Jeep Forum Classifieds
splitskater is offline
post #2 of 10 Old 12-04-2005, 11:55 AM
CWaldrop
CWaldrop's Avatar
Alignment and Centering the Steering Wheel write up found here
CWaldrop is offline
post #3 of 10 Old 12-04-2005, 11:58 AM Thread Starter
splitskater
yea i have seen that write i was just wondering if it could possibly be anything else that my cause this besides a simple alignment. thanx for the response
Warn Front bumper
Stinger guard
post #4 of 10 Old 12-04-2005, 12:06 PM
CWaldrop
CWaldrop's Avatar
My only suggestion would be to do the alignment and if symptoms still exist go from there. If everything looks fine in your steering components I would assume alignment.
CWaldrop is offline
post #5 of 10 Old 12-04-2005, 12:28 PM
igofshn
Locked @ both ends
igofshn's Avatar
I bet you bent something. Jeeps just don't go out of alignment on their own.
2007, 4 door, powered by a minivan engine, locked and riding on 35's.
igofshn is offline
post #6 of 10 Old 12-04-2005, 12:38 PM
Muddeprived
Muddeprived's Avatar
I'm betting you bent your tie-rod. It's the thin tube going across your axle, right in front. Check that (it may appear straight but could be bent towards the axle). It's a really cheap part though
2001 XJ Sport 4.5" LA
1999 TJ 2.5L 5spd 2" lift
Muddeprived is offline
post #7 of 10 Old 12-04-2005, 12:52 PM Thread Starter
splitskater
just did the front end aligmnent and recentered the steering wheel, my toe-in was fine, but it does feel like there is a slight pull but very little, it may just be me buggin out and thinking it is, the first thing i did when a get home was check for bent components, the tie-rod is not bent to the eye, but it could be just not noticeable, i didnt think it could just pop out of alignment like that either but i will take it to my friends shop for a second opinion. any other ideas i would like to hear them
Warn Front bumper
Stinger guard
post #8 of 10 Old 12-04-2005, 01:22 PM
otisdog
2008 WK
The drag link can start to bend out [straighten] right where that curve is. This will cause what you experienced. If you find your steering off-center again I'll bet that's what's happening. Sooner or later the steering will start to hit the swaybar link mounts. Compare it to another TJ. See how much clearance you have when your wheel is turned hard right.
jim
08 Grand Cherokee Overland
otisdog is offline
post #9 of 10 Old 12-04-2005, 02:37 PM
StealthTJ
Yup, you've undoubtably, bent the drag link.
If you're going to play the "when in doubt, throttle it out" silly game, then it's time to start upgrading
Fred
Base - '98 Sahara, 4.0L 6 cyl, Auto (swap from 5 sp)
Suspension- 4.0" Procomp Springs + 1 1/4" bl. Rear tri-link. Currie J arms, F&R. Warn hubs with WJ knuckles, custom cross over/hi-steering setup, Currie A/R Sway Bar.
HPD30/D44 (rear disk conversion, WJ dual piston caliber conversion in the front); Detroits; 4.56
Misc - Tera 2wd lo.
Tires - 35x12.50 MT/R's siped on 15x7 Champion Beadlocks.
Recovery - Warn XD9000i
StealthTJ is offline
post #10 of 10 Old 12-04-2005, 04:53 PM Thread Starter
splitskater
jim
unfortunately, i dont have another tj to compare to, i did have to turn the drag link several times to get the wheel straight, it didnt look bent but i will examine it more tomm when i have more light, thanx for the reply
Warn Front bumper
Stinger guard
Sway bar just popped out kylerobichaud TJ Wrangler Technical Forum 12 12-02-2008 05:08 PM
4-Low Popped Out??? grogie TJ Wrangler Technical Forum 12 08-21-2006 08:50 AM
Handle Popped Out On '06 TJ Chalice TJ Wrangler Technical Forum 11 07-24-2006 01:00 AM
Light popped up digitalrob TJ Wrangler Technical Forum 15 11-02-2005 11:18 AM
Popped out of 4H ksirmons TJ Wrangler Technical Forum 2 11-15-2001 05:54 PM
