*POP* going on in tight turns - JeepForum.com
post #1 of 14 Old 11-23-2004, 01:20 PM Thread Starter
htownjeep
What's that noise?
htownjeep's Avatar
Whenever I'm turning (such as a U-Turn or just going around a 90 corner) I hear a big POP coming from what sounds like the front wheels. When I'm turning to the left, it sounds like it's coming from the right wheel/tire. When I'm turning to the right, it sounds like it's coming from the left wheel/tire.
Any thoughts?! Kinda freaking me out!
Just started this morning by the way...
Drink upstream from the herd.
htownjeep is offline
post #2 of 14 Old 11-23-2004, 01:25 PM
James04TJ
James04TJ's Avatar
Do you still have stock swaybar links? It sounds like loose links.
*2004 TJ (Mine)* 1984 CJ-7 Buggy Project (Mine)* 1977 CJ-7 (Hers)*2005 Nylint Crawler (The Kid's)
James04TJ is offline
post #3 of 14 Old 11-23-2004, 01:27 PM Thread Starter
htownjeep
What's that noise?
htownjeep's Avatar
Why yes I do I believe. How much is that gonna cost me? Is it something easily done? I'll go search for a write-up...
post #4 of 14 Old 11-23-2004, 01:28 PM
AjRagno
Yes, my dogs and I agree
When mine failed, I'd bang as I went around turns. You can jack up the front, put a jack stands under the frame and let the wheels drop. If the links are bad, they should be loose and may even fall out of their sockets.
AjRagno is offline
post #5 of 14 Old 11-23-2004, 01:30 PM
AjRagno
Since you have a lift, get quick disconnects like JKS. You will need an extreme-heat source and a pitman arm puller to get the old links out of the sway bar.
AjRagno is offline
post #6 of 14 Old 11-23-2004, 01:35 PM Thread Starter
htownjeep
What's that noise?
htownjeep's Avatar
Is it something I can keep driving on for a while? Or will I kill myself or do permanent damage to my Jeep?
post #7 of 14 Old 11-23-2004, 01:35 PM
thebert
It could also be the ball joints as my passenger side joints are currently shot and make the same popping sound.
Terry.
thebert is offline
post #8 of 14 Old 11-23-2004, 01:40 PM
Optik45
No you can drive around on them safely for a while. I would also recommend JKS quick disconnects. Great Product.
2000 Shale Green Sport, I6, 5spd.
3.5" RE Standard
1" MORE BL
1" MORE MML
33x12.5" BFG MTs on Tech-1 Rock Crawlers
KC 130W Long Range Slimlites mounted on Windshield.
JKS Quick Disconnects
and a lot of other trinkets
Optik45 is offline
post #9 of 14 Old 11-23-2004, 01:49 PM
James04TJ
James04TJ's Avatar
First thing is to just make sure they are tight. Break out a 3/4" socket and a T-55 and tighten them up. That very well may solve your problem.
post #10 of 14 Old 11-23-2004, 01:54 PM Thread Starter
htownjeep
What's that noise?
htownjeep's Avatar
Thanks guys for all the input. Whenever the rain subsides, I'm going outside and sliding under the Jeep to check it out.
If anyone else has any other opinions, please share! But, sounds like it's a general consensus....
post #11 of 14 Old 11-24-2004, 07:50 AM
99TJSport
99TJSport's Avatar
I guess I need to check this out on mine this weekend as well. Although I've noticed my popping seems to be limited to sharp turns, like into parking spaces.
Jeff
08 Rubicon Unlimited, 2.5TF Lift, 285/70/17 BFG KM2s, lots of skids, MyGig, and both sets of doors/tops.
Parrothead Jeepers Union #24
99TJSport is offline
post #12 of 14 Old 11-24-2004, 08:35 AM
zex
Kinda wierd My Jeep is doing the same thing but when I turn mine I get multiple pops would this be the same thing as above ?
zex is offline
post #13 of 14 Old 11-24-2004, 08:38 AM Thread Starter
htownjeep
What's that noise?
htownjeep's Avatar
Sounds like JKS is about to get a lot of orders eh?
post #14 of 14 Old 11-24-2004, 08:45 AM
holyundrwr
holyundrwr's Avatar
mine pops quite a bit, i think it's ball joint and/or track bar related. not sway bar links for me, i took mine off months ago.
EASY ON THOSE CORNERS JETHRO!
'97 TJ Sahara 4" PRO COMP EXPLORER SUS LIFT
4.10'S D30/44 LOCKED 34 X 10.50 SUPER SWAMPERS
AIRAID INTAKE/ TB HELIX SPACER GIBSON HEADERS
LOTS MORE GOODIES, LOTS MORE TO COME!
BARBERPOLE DRIVESHAFT JEEP CLUB #1
holyundrwr is offline
Tires rub on tight turns. Jeep Guy 5 TJ Wrangler Technical Forum 7 03-08-2007 09:34 PM
The feel and handling of tight turns in 4wd Zulu TJ Wrangler Technical Forum 7 12-20-2005 12:34 PM
tight turns on tarmac huttonj TJ Wrangler Technical Forum 8 01-23-2005 11:22 AM
Wheels rub when i make tight turns.... Danlawson TJ Wrangler Technical Forum 11 01-22-2005 09:02 AM
Chirping on tight turns? DutchmanAZ TJ Wrangler Technical Forum 14 11-24-2004 08:41 AM
