Poor Heat In My '97 Tj. - JeepForum.com
post #1 of 9 Old 12-23-2005, 04:50 PM Thread Starter
Swedejeeper
The cabin heat in my TJ is really poor. The temperatur is up there but there is no volume. It has A/C and I'm wondering if that has got something to do with it. Any ideas why this is?
1997 TJ Red 2.5 L
BIG 50" wide 3X4 double square tube
front moose guard.
Swedejeeper is offline
post #2 of 9 Old 12-23-2005, 04:54 PM
Jerry Bransford
Administrator
Jerry Bransford's Avatar
Can you hear the fan and does it have the usual four different speeds?
Our Technical Staff is working to fix our database error problem, thank you for your patience.
Getting
Jerry Bransford is offline
post #3 of 9 Old 12-23-2005, 04:56 PM Thread Starter
Swedejeeper
Yes. The fan has all 4 speeds and it really works good. Was wondering if the A/C coil cuts down on the airflow. Am I wrong?
1997 TJ Red 2.5 L
front moose guard.
post #4 of 9 Old 12-23-2005, 05:51 PM
Jeepxj96
Jeepxj96's Avatar
You said the temp is up there and the blower motor works good. Are you saying the air comin out of the vents isnt hot?
Bob
1996 Land Rover Discovery with a bunch of stuff on super swampers
Jeepxj96 is offline
post #5 of 9 Old 12-23-2005, 05:56 PM Thread Starter
Swedejeeper
The air coming out is hot, but there is no volume. I don't believe that TJ's are lacking good heat. But before I start taking things apart.......
Andy.
1997 TJ Red 2.5 L
front moose guard.
post #6 of 9 Old 12-23-2005, 06:05 PM
Jerry Bransford
Administrator
Your TJ has a couple mechanically/vacuum actuated flapper doors that block or duct the air to the floor, defroster, or dash vents. Someone is going to have to get in there and find out if a cable has come off or what's gone wrong. Now that we know the fan works and things are getting hot, it's impossible to say what exactly is wrong with those flapper doors... you're gonna have to get in there and have a look.
Getting
post #7 of 9 Old 12-23-2005, 06:21 PM
Fritz R.
There is a couple of vacuum actuated flapper doors that might be causing the problem. Look up under the drivers side dash to the right and you should be able to see them. On mine the arm that attatches to the flapper broke off.
Fritz
'97 TJ, 4.0L, AW-4, Flipped D300/4:1, ARB's, D44, Swayloc, RK LA, PC coils, Rancho 9000's, 33x12.5 Trxus, etc.
Fritz R. is offline
post #8 of 9 Old 12-23-2005, 06:37 PM Thread Starter
Swedejeeper
Re: Poor cabin heat....
Thanks guys. Ithink I know what you are talking about. I'll have a look at those doors. Could be a simple problem, hopefully.
1997 TJ Red 2.5 L
front moose guard.
post #9 of 9 Old 12-23-2005, 06:49 PM Thread Starter
Swedejeeper
This is off topic, but I also own a little taildragger 2-seater Merlin GT bushplane. I had heard of this mountainstrip upp in the foothills of the Rockies northwest of Calgary. Last summer I drove my TJ upp there to have a look at what shape the strip was in and if I could land there. This year I flew up there just to find the strip full of cows, of all things. I guess I'll take the TJ the next time.
Andy.
1997 TJ Red 2.5 L
front moose guard.
Wrangler has poor heat and runs cool RednekWrangler YJ Wrangler Technical Forum 50 10-24-2013 02:55 PM
Poor Heat: what am I missing? richla TJ Wrangler Technical Forum 17 01-06-2010 03:00 PM
poor heat from heater core marko686 TJ Wrangler Technical Forum 5 09-20-2008 10:19 PM
Poor heat sheamus YJ Wrangler Technical Forum 2 09-08-2008 10:53 AM
Sad day, what to do with my poor YJ? hokiehoo YJ Wrangler Technical Forum 18 05-17-2007 08:50 AM
