poor heat from heater core - JeepForum.com
post #1 of 6 Old 09-07-2008, 07:56 PM Thread Starter
marko686
I have 2 problems here that i cannot figure out. 1st problem is my heater core. Even when my 98 TJ is warmed up i get warm not hot air if im lucky. I have had the heater core flushed once and that seemed to fix the problem for about a day. What do you guys recommend? Flush it again? replace heater core? 2nd problem has to do with my air vents. If the AC or heat is on any speed other than low...when i accelerate, sometimes the air will switch and only escape through the defrost vent by the windshield on top of the dash. All advice is greatly appreciated.
marko686 is offline
post #2 of 6 Old 09-07-2008, 08:01 PM
Jeepdude98
I have a 98 TJ and a 98 YJ. I had the same problems with both. Reverse flush heater core. disconnect both hoses from the engine and flush backwards with the garden hose!! You need PRESSURE!! Another way is to revers the hoses, which will work, with the addition of spline adaptors, but you will need to run the heator for several days to heat it up and flush it out good. Then once it is free and flowing, flush entire system and replace with clean water and antifreeze!!
Jeepdude98 is offline
post #3 of 6 Old 09-15-2008, 09:18 AM Thread Starter
marko686
thanks for the advice...i am going to try that this weekend. Did you have the same problem with the blower...That when accelerating the vents will switch from head, feet, to the defrost only?
marko686 is offline
post #4 of 6 Old 09-15-2008, 09:24 AM
Jerry Bransford
Administrator
Jerry Bransford's Avatar
Your engine produces less vacuum when you accelerate, and it is vacuum that controls much of your HVAC system. So it sounds like you have a vacuum leak since there's not enough vacuum to keep the HVAC working during acceleration. I'd look for a disconnected, split, or broken vacuum hose, or perhaps a broken vacuum manifold (a fancy word for something that distributes vacuum from one hose to several others).
Gone on vacation until August 25.
Jerry Bransford is offline
post #5 of 6 Old 09-15-2008, 10:11 AM
Tim
Tim's Avatar
one test the service manual suggests for your water pump is to turn on your heater.
it may be a sign of something else but lack of heat also points to failing water pump.
not saying yours is kaput, but it is a good thing to know if the signs are present.
97 TJ 4.0, AW-4, Clayton, A.R.B., Highly polished HP30, Super 88
There are no shortcuts to any place worth going
91 XJ 4.7
Tim is offline
post #6 of 6 Old 09-20-2008, 10:19 PM Thread Starter
marko686
I just flushed my heater and that solved the problem! thanx for all the advice and suggestions
marko686 is offline
new heater core and no heat schlik TJ Wrangler Technical Forum 18 02-12-2010 11:32 AM
No HEAT in TJ, even after flusing heater core upalms TJ Wrangler Technical Forum 16 01-03-2010 10:23 AM
Clogged heater core? Low heat? Here is my fix. igotdoo TJ Wrangler Technical Forum 2 12-29-2009 04:05 PM
no heat...heater core maybe? 94 Sahara YJ Wrangler Technical Forum 9 10-24-2005 06:52 AM
