Poly bumpstop spacer or washers - Page 2 - JeepForum.com
post #16 of 17 Old 06-28-2010, 09:42 AM
dcope17
Originally Posted by garybattles View Post
I epoxied hockey pucks for the front instead of drilling / bolting. Still on after 2 years. I did scruff the pucks with rough sandpaper before using the epoxy.
Did this exact thing too. Only 6 months but still there also.
Life with Christ can be explained like a Jeep...
Being in the Word... grows your tire size.
Prayer... gains more ground clearance.
Fellowship... Is like having a good spotter.
The more of these you have... the easier it is to get over obstacles in your path.
dcope17 is offline
post #17 of 17 Old 06-28-2010, 04:03 PM Thread Starter
Fargo
I seriously thought about doing the epoxy thing. But I was worried about it coming off. Sound like I maybe didn't have to worry about it. Oh well, I got mine bolted on now and I like that better because I don't have to pull the spring over that puck when installing new springs.
6spd manual
LJ Owners Group member #110
Fargo is offline
bumpstop
2'' Poly Spacer Question... FoxRacingJMC JK Wrangler Technical Forum 8 03-26-2010 10:22 AM
spacer and bumpstop question... jonny15 TJ Wrangler Technical Forum 1 02-25-2008 07:05 PM
poly spacer question rwmjeepjk JK Wrangler Technical Forum 8 05-22-2007 11:24 AM
Poly Spacer Question rwmjeepjk TJ Wrangler Technical Forum 1 01-04-2007 08:15 PM
Bumpstop spacer question... thejafe TJ Wrangler Technical Forum 1 11-19-2005 10:14 PM
