Quantcast POLL: Ok to Drive w/ rear drive shaft? - JeepForum.com
Go Back JeepForum.com > Models > Jeep Wrangler Forums > TJ Wrangler Technical Forum > POLL: Ok to Drive w/ rear drive shaft?
RUBICON EXPRESS Lift Kits and Accessories Available at BasSpartan Lockers FREE SHIPPING Excellent PricesFree Shipping on TIRES at KrawlOff-Road
View Poll Results: Ok to drive w/o rear Drive Shaft while waiting for new CV Shaft
Yes 25 86.21%
No (Then say why not) 4 13.79%
Voters: 29. You may not vote on this poll
Old 07-02-2008, 02:57 AM   #1
Libtekguy
POLL: Ok to Drive w/o rear drive shaft?
I'll be doing an SYE along with RE 4.5 (swapped for 3.5s) and a Terraflex skid. So I don't have a good idea on how long the new CV Driveshaft should be.
So, while I wait for Tom Woods to make said drive shaft, do you think it's ok to drive it with just the front drive shaft (with SYE installed, of course)?
I don't see any kind of problem with it (it is an open diff by the way). But maybe someone knows better (bad on the drive train or something).
Libtekguy is offline   Reply With Quote
Old 07-02-2008, 02:59 AM   #2
TheMightyGoat
It's been done of course but I think I remember hearing that it's inadvisable to do so for an extended period of time. I forget why.
TheMightyGoat is offline   Reply With Quote
Old 07-02-2008, 07:26 AM   #3
Wheelin98TJ
JEEP FREAK
Wheelin98TJ's Avatar
Its fine.
Just don't be doing front wheel peel burnouts.
98 TJ
Wheelin98TJ is offline   Reply With Quote
Old 07-02-2008, 07:31 AM   #4
never monday
the reason it will work for you is the SYE. if you didn't have it, the TC would leak from the output
Get Savvy
never monday is offline   Reply With Quote
Old 07-02-2008, 07:56 AM   #5
Wheelin98TJ
JEEP FREAK
It shouldn't leak even w/o an SYE.
The 231 t-case used in TJs has an output shaft seal.
Its not like the 231 t-case used in YJs where it relied upon the driveshaft to make the seal.
98 TJ
Old 07-02-2008, 08:51 AM   #6
Sweeney
The problem is, if you remove the rear drive shaft there is nothing to hold the slip yoke in place. The slip yoke has the sealing surface on the 231.
Sweeney is offline   Reply With Quote
Old 07-02-2008, 08:58 AM   #7
rudyyj
not on TJs the output shaft has the seal as stated above
rudyyj is offline   Reply With Quote
Old 07-02-2008, 09:37 AM   #8
Sweeney
On my '98 the only seal was on the slip yoke.
Old 07-02-2008, 09:50 AM   #9
DaOne
Just call TW and tell them what you're installing, and they can make a shaft for you ahead of time. It's done all the time.
...Sometimes, the more you see, the less you understand...
I miss my Jeep. On the hunt for a replacement.
DaOne is offline   Reply With Quote
Old 07-02-2008, 11:37 AM   #10
Twizted
Twizted's Avatar
When the yoke on my D35 broke. I ran on front wheels for about 3 weeks waiting for the SYE kit, took it easy and everything was fine. When the D35 broke, I ran it on front wheels for about 4 weeks waiting for an 8.8 swap. I drove it normal then even on the highway, no issues even with 3.07 gears and 32's. It will spin the tires easily in the rain and it didn't like tight turns.
00' TJ Sport 4.0 5spd: D30/8.8 w/Tru-Tracs F/R and 4.56's
Teraflex 3", 35x12.50's on 15x10 Eagle's, Airraid intake, Borla catback, Xenon Flares, Fabtech SYE and driveshaft, JKS Quicker Discos, XD Security, just getting started...
Originally Posted by mrblaine
After all, I are educted.
Originally Posted by Muddy Rocks
Beer makes the world go round. (thats why it leans a little when it rotates)
Twizted is offline   Reply With Quote
Old 07-02-2008, 11:42 AM   #11
Jakemd98
Choosy moms choose jeep.
Jakemd98's Avatar
The only reason why i would say no, is because that is a lot of stress to put on JUST your front axle. It's only a Dana 30... while it is a tough little axle, to put 100% of the jeeps power and weight on it would be a lot of stress. For temporary use you should be fine, and there should be no mechanical problems with the drive-train. But i wouldn't run it very much until you get the rear put back together.
Jake Davis
97 Jeep Wrangler
4.0, 5 speed AX-15, D44 & Ford 8.8 w/Detroit - 4.88, NP-231, OME 2.5" coils w/1.25" spacers on front, 1.25" JKS BL, 35X12.50R15 KM2 on 15x8 Eagle alloys, Banks Header, Banks Monster Exhaust, Brown Dog MML, Rhino Liner, Tuffy Glove Box, AtoZ Rockers, Optima Red Top Battery.
1998 GMC Yukon
Wilmington weekly 4x4 meet
Jakemd98 is offline   Reply With Quote
Old 07-02-2008, 11:46 AM   #12
WILLY05TJ
in first and second be sure to stay off heavy throttle it'll break the tires loose w/o a problem even with 35's and 37's
it may be funny to see your jeep smoke off the front tires but it sucks when you stop moving (broken front driveshaft)
WILLY05TJ is offline   Reply With Quote
Old 07-02-2008, 12:13 PM   #13
Libtekguy
Thanks for all of the input. I've read various posts before using the Search button about it and couldn't get solid answer on the matter. Obviously driving it in "front wheel drive" is less than ideal. Sounds like the consensus is go for it and just be careful with the skinny pedal.
Old 07-02-2008, 12:20 PM   #14
alvinl
You will be fine. I was in the same boat as you. I installed my SYE then waited a couple weeks for my rear driveshaft to be delivered. I drove it around town and on the highway. No leaks, nothing broke. It does steer different in fwd but that was all I noticed different.
"Only two things are infinite, the universe and human stupidity; and I'm not sure about the former." - Albert Einstein
http://www.venemousduckracing.com
alvinl is offline   Reply With Quote
Old 07-02-2008, 12:25 PM   #15
goldswim5
yeah you can do it, I'm doing it right now while I wait for my shaft. The case won't leak just dont take corners under power very hard if you can avoid it, it makes some uncomfortable movements if you do.
'99 Cherokee
'01 3/4 ton 6spd Powerstroke (The Tow Pig)
I wheel at SMORR
goldswim5 is offline   Reply With Quote
Glock Forum
