-   TJ Wrangler Technical Forum (http://www.jeepforum.com/forum/f9/)
-   -   POLL: Ok to Drive w/ rear drive shaft? (http://www.jeepforum.com/forum/f9/poll-ok-drive-w-rear-drive-shaft-577552/)
Libtekguy 07-02-2008 01:57 AM
POLL: Ok to Drive w/o rear drive shaft?
I'll be doing an SYE along with RE 4.5 (swapped for 3.5s) and a Terraflex skid. So I don't have a good idea on how long the new CV Driveshaft should be.
So, while I wait for Tom Woods to make said drive shaft, do you think it's ok to drive it with just the front drive shaft (with SYE installed, of course)?
I don't see any kind of problem with it (it is an open diff by the way). But maybe someone knows better (bad on the drive train or something).
TheMightyGoat 07-02-2008 01:59 AM
It's been done of course but I think I remember hearing that it's inadvisable to do so for an extended period of time. I forget why.
Wheelin98TJ 07-02-2008 06:26 AM
Its fine.
Just don't be doing front wheel peel burnouts. :laugh:
never monday 07-02-2008 06:31 AM
the reason it will work for you is the SYE. if you didn't have it, the TC would leak from the output
Wheelin98TJ 07-02-2008 06:56 AM
It shouldn't leak even w/o an SYE.
The 231 t-case used in TJs has an output shaft seal.
Its not like the 231 t-case used in YJs where it relied upon the driveshaft to make the seal.
Sweeney 07-02-2008 07:51 AM
The problem is, if you remove the rear drive shaft there is nothing to hold the slip yoke in place. The slip yoke has the sealing surface on the 231.
rudyyj 07-02-2008 07:58 AM
not on TJs the output shaft has the seal as stated above
Sweeney 07-02-2008 08:37 AM
On my '98 the only seal was on the slip yoke.
DaOne 07-02-2008 08:50 AM
Just call TW and tell them what you're installing, and they can make a shaft for you ahead of time. It's done all the time.
Twizted 07-02-2008 10:37 AM
When the yoke on my D35 broke. I ran on front wheels for about 3 weeks waiting for the SYE kit, took it easy and everything was fine. When the D35 broke, I ran it on front wheels for about 4 weeks waiting for an 8.8 swap. I drove it normal then even on the highway, no issues even with 3.07 gears and 32's. It will spin the tires easily in the rain and it didn't like tight turns.
Jakemd98 07-02-2008 10:42 AM
The only reason why i would say no, is because that is a lot of stress to put on JUST your front axle. It's only a Dana 30... while it is a tough little axle, to put 100% of the jeeps power and weight on it would be a lot of stress. For temporary use you should be fine, and there should be no mechanical problems with the drive-train. But i wouldn't run it very much until you get the rear put back together. :2c:
WILLY05TJ 07-02-2008 10:46 AM
in first and second be sure to stay off heavy throttle it'll break the tires loose w/o a problem even with 35's and 37's
it may be funny to see your jeep smoke off the front tires but it sucks when you stop moving (broken front driveshaft)
Libtekguy 07-02-2008 11:13 AM
Thanks for all of the input. I've read various posts before using the Search button about it and couldn't get solid answer on the matter. Obviously driving it in "front wheel drive" is less than ideal. Sounds like the consensus is go for it and just be careful with the skinny pedal.
alvinl 07-02-2008 11:20 AM
You will be fine. I was in the same boat as you. I installed my SYE then waited a couple weeks for my rear driveshaft to be delivered. I drove it around town and on the highway. No leaks, nothing broke. It does steer different in fwd but that was all I noticed different.
goldswim5 07-02-2008 11:25 AM
yeah you can do it, I'm doing it right now while I wait for my shaft. The case won't leak just dont take corners under power very hard if you can avoid it, it makes some uncomfortable movements if you do.
The time now is 03:10 PM.
