Poll: JKS ACOS and Quicker Disco's. on stock TJ? Other?
| Introducing MONSTALINER™ UV Permanent DIY Roll On Bed Line | GR8TOPS Introduces the Exogate HD Tire Carrier | 1984-2001 Jeep XJ Cherokee Lift Kits 3-4.5" with Full |
| View Poll Results: Stock TJ: Suspension help? | |||
| JKS combo package: JKS Quicker Disco's and JKS ACOS |
2 | 8.70% |
| RE 4" suspension lift with JKS Quicker Discos. |
4 | 17.39% |
| RE 4" suspension lift with Currie AntiRock |
14 | 60.87% |
| Other (please specify in thread post) |
3 | 13.04% |
| Voters: 23. You may not vote on this poll | |||
#1 | |
Maybe I should make this a poll: JKS combo vs. 4" lift kit. I'll see if that works.
Options: #1 - JKS combo package fo Quicker Disco's and JKS ACOS, #2 - RE 4" suspension lift with JKS discos. #3 - RE 4" suspension lift with Currie AntiRock #4 - other (please describe). I have an '03 TJ Sport that is riding on nothing but 31.5's and a totally stock suspension. I'm not in need (yet) of a complete suspension lift kit, but I'm sure I'll eventually get there (4" RE maybe?). For now though, this is my DD and a way for the wife and I to run away from a pubescent and very hormonal 14 yr. old daughter and go camping. ![]() The stock suspension is getting old and tired, so I know something needs to be done to help that issue. On the front I have a Smittybilt SRC bumper and Warn winch plate weighing the front end down. I'm planning on a warn PowerPlant winch, so will make the front end extra heavy. As far as the rear, right now when we go camping, the gear can make the rear sag a fair bit. I want to eventually add a Body Armor 54" swing away to the rig so I also know that this will cause the rear to sag even more. The Bushwacker Flat Fender Flares are also planned. I like being on 31.5's right now for the DD aspect, but would eventually like to get up to 33's. I've been looking at suspension options that won't cost me an arm and a leg and I came across the JKS Quicker Disco's and the JKS ACOS (saw the ACOS Pro too). Here's my thinking and where I need forum members help and advice. *Note: The disco's. I want simply for articulation and ease of doing what I already do: Disco. the sway bar links when off-road. Should I do the JKS package and be able to disconnect and have adjustable ride height with the ACOS system and be able to adjust front and rear heights accordingly to my needs (DD vs. camping with the ability to go a little more extreme than the stock suspension will allow right now)? Or should I invest in a full suspension package such as the RE 4" with some discos and then worry about front/rear sag once everything's installed (swing away, winch, etc.)? Any informed opinions and ideas would be appreciated. Has anyone used the combo of the JKS products like I'm describing to make for extra ride height and sway bar ease? Whatever your vote, please comment. Your help/advise/experience would be appreciated. Thanks in advance folks! ![]()
#2 |
Cant edit my user title
ACOS aren't exactly the best for on the fly adjustment. They take quite a bit of work to readjust. If that's what you're considering them for, I'd rethink them.
That being said, I think 2.5 OME and 1.25 JKS = heaven on earth. It equals out to about 4" in the end if you get the stiffer OME springs. Best part, you have room for a tummy tuck / gas tank tuck. Give Dirk at dpgoffroad.com a call, he'll steer you towards the right direction.
Andy, KD8EIA | USN Jeep Hull # 66 | ΜOΛΩΝ ΛΑΒΕ |
| My Jeep's Thread | My Photobucket | San Diego Jeepers!! | VBARC | Military Jeepers | "Don't take life too seriously, You'll never make it out alive." "A government big enough to give you everything you want is a government big enough to take from you everything you have" - Gerald R. Ford in an address to a joint session of Congress on August 12, 1974 |
#3 | |
#4 |
I think he's talking about jks 1.25BL
Steven |
#5 |
bump...bump...bump
#6 |
Yep.
Did you check out dpgoffroad.com?
#7 |
I'm looking at dpg right now thanks to your post. I have to take into account the fact that whatever prices I see on an American site has to be currency converted to my Canadian dollars. OME seems to be the way to go though. I like the fact that their "Deluxe" kit on the dpg site includes the JKS Discos., BL and MM's. That's an advantage!
#8 |
bumpity bump bump
#9 |
Yep DPG makes a very very complete kit.
But of your choices on the poll, I would have to pick the 4" RE with AntiRock
#10 |
#11 | |
you're not fumbling with discos and you still have your anti swaybar on the trail...
1997 TJ SE - Emeral Green Pearl 2.5L : AX-5 : NP231, D30HP : D44 : 4:88 : Front Aussie 2.5" OME lift, OME LT shocks, 2" BL, Currie Control Arms, Currie HD Steering, Currie Trackbars, Warn M8000 Custom Front and Rear Bumpers, Custom Rock Sliders, OBA 33" x 12.5" x 15" Goodyear MTRs, Black Steelies |
#12 | |
As for the RE 4", it's just a nice kit. Well put together, great warranty and customer service, and from what the guys around here say it's performs pretty dang well.
#13 |
I think you want to do more research on RE. Try googling "rubicon express" bushings and once you have read thru the issues you can research better control arms. Look at Currie or Rock Krawler.
Friends don't let Friends run Bosch My Wifes Cake Site - Check the Jeep Under Carved & 3D |
#14 |
For the wheeling that it sounds like he'll be doing, I think Rock Krawler will be a bit out of his needs. Currie would be quite the overkill, but I can't say anything bad about their system. I've seen some amazing Jeeps with their set up.
#15 |
It may be, but I keep seeing RE referred to as the "be all" lift kit and everyone seems to gloss over the bushing issues or blame it on improper install. The OP needs to know that RE has issues with their bushings and they have had for years. They have switched suppliers to try and solve the issue but it is still to early to tell if they have fixed the issue.
| Thread Tools | |
Previous Thread
Next Thread
| Suggested Threads |
