Poison Spyder rock guards installation - JeepForum.com
post #1 of 4 Old 04-27-2011, 06:17 AM Thread Starter
JeeporJag
Junior Member
I helped a friend pull off some rusted Poisonspyder rock guards on an LK. He is looking into getting them powder coated. They go between the steel body mount outrigger and the upper rubber body bushing. So they lift the body on the 3 mounts on each side. The other body mounts at the front and back will be about 1/8 inch short. The directions on the PS web page donít say anything about cutting the 6 rubber mount down to compensate for the thickness of the rock guards. Is it necessary/worth the trouble to cut the 6 mounts down 1/8 to compensate for the rock guard thickness?
If damage is not likely itís a road.
JeeporJag is offline
post #2 of 4 Old 04-27-2011, 06:48 AM
athos76
Nope. The rubber will compress when you torque them back down
2006 I6 6-Speed X, 33" Goodyear Duratrac, 8.8.
athos76 is offline
post #3 of 4 Old 04-28-2011, 02:11 AM
DoGood
installation instructions for my poison spyder rocker guards for my TJ said to cut the rubber body mounts.
^I wouldn't listen to what I say. I don't know what I'm talking about. Please use the search feature.
DoGood is offline
post #4 of 4 Old 05-10-2011, 07:28 AM
epeck87
ive heard of some people cuting theirs and some people leaving them alone without any problems. i will probably put mine on a belt sander for a few seconds when i install my rockers just cuz it only takes a minute.
Associates Degree in automotive technology
A1-A8 ASE MASTER CERTIFIED TOYOTA MECHANIC
epeck87 is offline
Rock Crusher vs Poison Spyder tparker15 TJ Wrangler Technical Forum 10 05-21-2006 04:11 PM
Poison Spyder Customs Rocker guards Rubi Unlimited TJ Wrangler Technical Forum 11 05-09-2006 08:50 AM
Rock-It-Man or Poison Spyder Rockers Dozer. TJ Wrangler Technical Forum 37 12-05-2005 12:54 AM
Poison Spyder Rock Ring MeanGrnYJ YJ Wrangler Technical Forum 1 02-17-2005 08:54 PM
