Poison Spyder Flares - JeepForum.com
post #1 of 6 Old 08-30-2013, 09:15 AM Thread Starter
bigorangeyj
Just a quick question. Can steel poison spyder defender flares be welded on to the body itself, or do I need the corner armor?
02BLKTJ-35" MTR/K's, savvy 4", 4.88's, Detroit True Trac 44 rear, Aussie HP 30 front, Big Stereo.
bigorangeyj is offline
post #2 of 6 Old 08-30-2013, 09:29 AM
biffgnar
biffgnar's Avatar
Defenders are not just flares. They are full fender replacements. Also, aren't Defenders front only so not sure how corner armor figures into it. Maybe you mean Crushers where I think they offer them as flare/corner combos or flare only.
Romney in 2020!
biffgnar is offline
post #3 of 6 Old 08-30-2013, 10:19 AM
DRIVESHAFT
Yes they do make weld on rear Defender steel flares only. I had tabs welded on them and bolt them on.
DRIVESHAFT is offline
post #4 of 6 Old 08-30-2013, 10:28 AM Thread Starter
bigorangeyj
DRIVESHAFT, do you have them bolted straight to the body or some kind of armor?
http://shop.poisonspyder.com/Jeep-Re.../14-05-070.htm
post #5 of 6 Old 08-30-2013, 08:22 PM
DRIVESHAFT
Yes I run the Savvy corners with factory flares holes. Mine are the Aluminum flares.
post #6 of 6 Old 08-31-2013, 05:46 AM
rda616
I wouldn't suggest welding them to the body. Even bolting them on without full corners could cause body damage if you hit something with one. I would run trimmed factory rears until you by corners.
rda616 is offline
