Plugs maybe? - JeepForum.com
post #1 of 5 Old 12-19-2005, 10:24 AM Thread Starter
spider10382
Plugs maybe?
So just recently my check engine light has gone on. The engine seems to be idling a little rough. When it started I assumed it was just the recent cold weather taking its toll. i have checked oil and my fluids are all good. I thought that may have been the case so I reset the light but it came back on today. what I have noticed while driving at a constant speed the engine feels really jerky. It feels like something probably isnt firing right. I am hoping its not more than the plugs and I am assuming its not the clutch because why would the check engine light come on. I'll hopefully be able to get it looked at within the next couple of days but any suggestions on what I might be able to check for and possible correct myself would be great. I suppose knowing it is a 00 tj sport roughly 55k mi on it would help
spider10382 is offline
post #2 of 5 Old 12-19-2005, 10:33 AM
Wheelin98TJ
JEEP FREAK
Wheelin98TJ's Avatar
Have you pulled the codes yet?
This is where I would start.
Wheelin98TJ is offline
post #3 of 5 Old 12-19-2005, 10:42 AM Thread Starter
spider10382
no not yet that would be the next step
post #4 of 5 Old 12-19-2005, 10:56 AM
Wheelin98TJ
JEEP FREAK
It should be the first step.
Interent diagnosis is just someone's best guess. You'll get a definite answer by pulling the codes.
Do you know the key trick? On (not cranking) and off 3 times. Leave it on the 3rd or 4th time (I can't remember, my 98 does not do this). Codes will then display in the odometer.
post #5 of 5 Old 12-19-2005, 11:30 AM Thread Starter
spider10382
no i didnt know that trick but hopefully it will work I will give it a shot and hopefully it'll help
Need Spark Plugs - Can't find the Champion Truck Plugs #4412 2004JeepTJ TJ Wrangler Technical Forum 29 09-17-2011 08:37 PM
E3 plugs? antec YJ Wrangler Technical Forum 4 07-12-2009 08:20 AM
Plugs gargyle TJ Wrangler Technical Forum 1 07-11-2009 09:58 AM
Can someone ID these plugs please Reverb YJ Wrangler Technical Forum 9 04-06-2009 08:33 AM
Splitfire Plugs vs. Standard Plugs Alphadux TJ Wrangler Technical Forum 8 11-19-2003 06:35 PM
